#include <math.h>#include <string.h>#include <stdlib.h>#include "bft_error.h"#include "bft_mem.h"#include "bft_printf.h"#include "cs_block_dist.h"#include "cs_math.h"#include "cs_mesh.h"#include "cs_mesh_builder.h"#include "cs_mesh_cartesian.h"
Include dependency graph for cs_mesh_cartesian.c:Functions | |
| cs_mesh_cartesian_params_t * | cs_mesh_cartesian_get_params (void) |
| Return pointer to cartesian mesh parameters structure. More... | |
| void | cs_mesh_cartesian_create (void) |
| Create cartesian mesh structure. More... | |
| void | cs_mesh_cartesian_define_simple (int ncells[3], cs_real_t xyz[6]) |
| Define a simple cartesian mesh with a constant step in all directions. More... | |
| void | cs_mesh_cartesian_define_dir_user (int idir, int ncells, cs_real_t vtx_coord[]) |
| Define directions parameters based on a user input. More... | |
| void | cs_mesh_cartesian_define_from_csv (const char *csv_file_name) |
| Define a simple cartesian mesh based on a CSV file. CSV file needs to contain : (1) First line which is empty or contains a header (2) Second line containing number of vertices per direction: format is 'nx;ny;nz' (3) Third line is empty or contains a header (4) Fourth line and onwards contains vertices coordinates for each direction. Format is "X1[i];X2[i];X3[i]" for index i. If current vertex index is beyond max value for a given direction, an empty value is expected. For example, if for index 'j' the first direction is empty, format is : ';X2[j];X3[j]'. More... | |
| void | cs_mesh_cartesian_define_dir_params (int idim, cs_mesh_cartesian_law_t law, int ncells, cs_real_t smin, cs_real_t smax, cs_real_t progression) |
| Define parameters for a given direction. More... | |
| int | cs_mesh_cartesian_need_build (void) |
| Indicate if a cartesian mesh is to be built. More... | |
| int | cs_mesh_cartesian_get_ncells (int idim) |
| Get number of cells in a given direction. More... | |
| void | cs_mesh_cartesian_connectivity (cs_mesh_t *m, cs_mesh_builder_t *mb, long echo) |
| Build unstructured connectivity needed for partitionning. More... | |
| void | cs_mesh_cartesian_params_destroy (void) |
| Destroy cartesian mesh parameters. More... | |
| void cs_mesh_cartesian_connectivity | ( | cs_mesh_t * | m, |
| cs_mesh_builder_t * | mb, | ||
| long | echo | ||
| [in] | m | pointer to cs_mesh_t structure |
| [in] | mb | pointer to cs_mesh_builder_t structure |
| [in] | echo | verbosity flag |
| void cs_mesh_cartesian_create | ( | void | ) |
| void cs_mesh_cartesian_define_dir_params | ( | int | idim, |
| cs_mesh_cartesian_law_t | law, | ||
| int | ncells, | ||
| cs_real_t | smin, | ||
| cs_real_t | smax, | ||
| cs_real_t | progression | ||
| [in] | idim | Geometrical direction: 0->X, 1->Y, 2->Z |
| [in] | law | 1D discretization law: constant, geometric or parabolic |
| [in] | ncells | Number of cells for this direction |
| [in] | smin | Min coordinate value for this direction |
| [in] | smax | Max coordinate value for this direction |
| [in] | progression | Progression value, only used for geometric or parabolic laws. |
| void cs_mesh_cartesian_define_dir_user | ( | int | idir, |
| int | ncells, | ||
| cs_real_t | vtx_coord[] | ||
| [in] | idir | Direction index. 0->X, 1->Y, 2->Z |
| [in] | ncells | Number of cells for the direction |
| [in] | vtx_coord | Array of size ncells+1 containing 1D coordinate values for vertices on the given direction |
| void cs_mesh_cartesian_define_from_csv | ( | const char * | csv_file_name | ) |
| [in] | csv_file_name | name of CSV file containing mesh information. |
| void cs_mesh_cartesian_define_simple | ( | int | ncells[3], |
| cs_real_t | xyz[6] | ||
| [in] | ncells | Array of size 3 containing number of cells in each direction |
| [in] | xyz | Array of size 6 containing min values, followed by max values for the three directions. |
| int cs_mesh_cartesian_get_ncells | ( | int | idim | ) |
| [in] | idim | Index of direction: 0->X, 1->Y, 2->Z |
| cs_mesh_cartesian_params_t* cs_mesh_cartesian_get_params | ( | void | ) |
| int cs_mesh_cartesian_need_build | ( | void | ) |
| void cs_mesh_cartesian_params_destroy | ( | void | ) |
