#include "cs_defs.h"#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include <mpi.h>#include "bft_error.h"#include "bft_mem.h"#include "bft_printf.h"#include "cs_mesh.h"#include "cs_mesh_connect.h"#include "cs_parall.h"#include "cs_prototypes.h"#include "cs_selector.h"#include "cs_timer.h"#include "fvm_defs.h"#include "fvm_nodal_from_desc.h"#include "cs_medcoupling_utils.hxx"#include <MEDCoupling_version.h>#include <MEDCouplingUMesh.hxx>#include <MEDCouplingField.hxx>#include <MEDCouplingFieldDouble.hxx>#include "MEDCouplingRemapper.hxx"
Include dependency graph for cs_medcoupling_utils.cxx:| void cs_medcoupling_mesh_copy_from_base | ( | cs_mesh_t * | csmesh, |
| cs_medcoupling_mesh_t * | pmmesh, | ||
| int | use_bbox | ||
copy a cs_mesh_t into a cs_medcoupling_mesh_t
| [in] | csmesh | pointer to the cs_mesh_t struct to copy data from |
| [in] | pmmesh | pointer to the cs_medcoupling_mesh_t for copy |
| [in] | use_bbox | flag indicating if a reduced bounding is used. Usefull for interpolation to reduce the matrix sice. 0: Do not use a reduced bbox 1: Use a reduced bbox |
| cs_medcoupling_mesh_t* cs_medcoupling_mesh_create | ( | const char * | name, |
| const char * | selection_criteria, | ||
| int | elt_dim | ||
create a new cs_medcoupling_mesh_t instance
| [in] | name | name of the mesh |
| [in] | selection_criteria | selection criteria (entire mesh or part of it) |
| [in] | elt_dim | dimension of elements. 2: faces 3: cells |
| void cs_medcoupling_mesh_destroy | ( | cs_medcoupling_mesh_t * | mesh | ) |
Destroy a cs_medcoupling_mesh_t.
| [in] | mesh | cs_medcoupling_mesh_t pointer |
| const cs_lnum_t* cs_medcoupling_mesh_get_connectivity | ( | cs_medcoupling_mesh_t * | m | ) |
Return a cs_medcoupling_mesh_t structure's (parent) elements list.
| int cs_medcoupling_mesh_get_dim | ( | cs_medcoupling_mesh_t * | m | ) |
Return a cs_medcoupling_mesh_t structure's spatial dimension.
| const cs_lnum_t* cs_medcoupling_mesh_get_elt_list | ( | cs_medcoupling_mesh_t * | m | ) |
| cs_lnum_t cs_medcoupling_mesh_get_n_elts | ( | cs_medcoupling_mesh_t * | m | ) |
Return a cs_medcoupling_mesh_t structure's number of elements.
