cs_les_inflow.h File Reference
#include "cs_zone.h"
+ Include dependency graph for cs_les_inflow.h:
Data Structures
struct  cs_inflow_sem_t
Typedefs
typedef struct _cs_inlet_t cs_inlet_t
Enumerations
enum  cs_les_inflow_type_t { CS_INFLOW_LAMINAR, CS_INFLOW_RANDOM, CS_INFLOW_BATTEN, CS_INFLOW_SEM }
void synthe (const cs_real_t *const ttcabs, const cs_real_t dt[], cs_real_t rcodcl[])
void cs_les_inflow_initialize (void)
 Creation of structures for the LES inflows. More...
void cs_les_inflow_finalize (void)
 Finalize turbulent inflow generation API. More...
void cs_les_inflow_add_inlet (cs_les_inflow_type_t type, bool volume_mode, const cs_zone_t *zone, int n_entities, int verbosity, const cs_real_t *vel_r, cs_real_t k_r, cs_real_t eps_r)
 Add an inlet definition for synthetic turbulence inflow generation. More...
void cs_les_synthetic_eddy_restart_read (void)
void cs_les_synthetic_eddy_restart_write (void)
void cs_les_synthetic_eddy_method (cs_lnum_t n_points, const cs_lnum_t elt_ids[], const cs_real_3_t point_coordinates[], const cs_real_t *point_weight, int initialize, int verbosity, cs_inflow_sem_t *inflow, cs_real_t t_cur, const cs_real_3_t vel_m_l[], const cs_real_6_t rij_l[], const cs_real_t eps_l[], cs_real_3_t fluctuations[])
 Generation of synthetic turbulence via the Synthetic Eddy Method (SEM). More...
void cs_les_rescale_fluctuations (cs_lnum_t n_points, const cs_real_6_t statistics[], cs_real_3_t fluctuations[])
 Rescale fluctuations by statistics following the Lund method. More...
void cs_les_synthetic_eddy_set_n_restart_structures (int n_structures)
 Set number of structures used for volume SEM when restarting from another turbulence model. More...
int cs_les_synthetic_eddy_get_n_restart_structures (void)
 Return number of structures used for volume SEM when restarting from another turbulence model. More...
void cs_les_inflow_get_restart (bool *allow_read, bool *allow_write)
 Query behavior of the LES inflow module in case of restart. More...
void cs_les_inflow_set_restart (bool allow_read, bool allow_write)
 Define behavior of the LES inflow module in case of restart. More...
void cs_user_les_inflow_define (void)
 Define parameters of synthetic turbulence at LES inflow. More...
void cs_user_les_inflow_update (const cs_zone_t *zone, cs_real_t vel_r[3], cs_real_t *k_r, cs_real_t *eps_r)
 Update of the characteristics of a given synthetic turbulence inlet. More...
void cs_user_les_inflow_advanced (const cs_zone_t *zone, cs_real_3_t vel_l[], cs_real_6_t rij_l[], cs_real_t eps_l[])
 Definition of mean velocity, Reynolds stresses and dissipation rate for each boundary face of the given synthetic turbulence inlet. More...
Typedef Documentation
◆ cs_inlet_t
◆ cs_les_inflow_type_t
Enumerator
CS_INFLOW_LAMINAR
Laminar fluctuations (i.e no fluctuation)
CS_INFLOW_RANDOM
Gaussian random fluctuation
CS_INFLOW_BATTEN
Fluctuations generated by the Batten method
CS_INFLOW_SEM
Fluctuations generated by the Synthetic Eddy Method
◆ cs_les_inflow_add_inlet()
void cs_les_inflow_add_inlet ( cs_les_inflow_type_t  type,
bool  volume_mode,
const cs_zone_t zone,
int  n_entities,
int  verbosity,
const cs_real_t vel_r,
cs_real_t  k_r,
cs_real_t  eps_r
Remarks
  • eps_r is used only for CS_INFLOW_BATTEN and CS_INFLOW_SEM types.
  • Strictly positive values are required for k_r and eps_r.
  • Finer definition of the statistics of the flow at the inlet can be done later using cs_user_les_inflow_advanced.
[out]typetype of inflow method at the inlet
[out]volume_modeif true, generate turbulence over the whole domain (only if type is CS_INFLOW_SEM)
[in]zonepointer to associated boundary zone
[out]n_entitiesnumber of structures or modes
[out]verbosityverbosity level
[out]vel_rreference mean velocity
[out]k_rreference turbulent kinetic energy
[out]eps_rreference turbulent dissipation
◆ cs_les_inflow_finalize()
void cs_les_inflow_finalize ( void  )
◆ cs_les_inflow_get_restart()
void cs_les_inflow_get_restart ( bool *  allow_read,
bool *  allow_write
See cs_les_synthetic_eddy_set_restart for details.
[out]allow_readpointer to read flag, or NULL
[out]allow_writepointer to write flag, or NULL
◆ cs_les_inflow_initialize()
void cs_les_inflow_initialize ( void  )
◆ cs_les_inflow_set_restart()
void cs_les_inflow_set_restart ( bool  allow_read,
bool  allow_write
By default, a restart file is read if present, and a checkpoint written. If not read, synthetic fluctuations are re-initialized.
[in]allow_readallow reading a relevant checkpoint if present
[in]allow_writeallow writing a relevant checkpoint if present
By default, a specific file is read if present in the restart folder, and files written in the checkpoint folder at global checkpoint intervals.
◆ cs_les_rescale_fluctuations()
void cs_les_rescale_fluctuations ( cs_lnum_t  n_points,
One assumes that the statistics are interlaced and ordered as follows: <u'u'> <v'v'> <w'w'> <u'v'> <v'w'> <u'w'>
[in]n_pointslocal number of points where turbulence is generated
[in]statisticsstatistics (i.e. Reynolds stresses)
◆ cs_les_synthetic_eddy_get_n_restart_structures()
int cs_les_synthetic_eddy_get_n_restart_structures ( void  )
number of structures for initialization
◆ cs_les_synthetic_eddy_method()
void cs_les_synthetic_eddy_method ( cs_lnum_t  n_points,
const cs_real_t point_weight,
int  initialize,
int  verbosity,
cs_inflow_sem_t inflow,
cs_real_t  t_cur,
[in]elt_idslocal id of inlet elements
[in]point_coordinatespoint coordinates
[in]point_weightpoint weights (surface, volume or NULL)
[in]initializeinitialization indicator
[in]verbosityverbosity level
[in]inflowpointer to structure for Batten method
[in]t_curcurrent time
[in]vel_m_lmean velocity at each point
[in]rij_lreynolds stresses at each point
[in]eps_ldissipation rate at each point
[out]fluctuationsvelocity fluctuations at each point
[in]elt_idslocal id of inlet boundary faces
[in]rij_lReynolds stresses at each point
◆ cs_les_synthetic_eddy_restart_read()
void cs_les_synthetic_eddy_restart_read ( void  )
◆ cs_les_synthetic_eddy_restart_write()
void cs_les_synthetic_eddy_restart_write ( void  )
◆ cs_les_synthetic_eddy_set_n_restart_structures()
void cs_les_synthetic_eddy_set_n_restart_structures ( int  n_structures)
[in]n_structuresnumber of structures for initialization
◆ cs_user_les_inflow_advanced()
void cs_user_les_inflow_advanced ( const cs_zone_t zone,
cs_real_t  eps_l[]
Accurate definition of mean velocity, Reynolds stresses and dissipation rate for each boundary face of the given synthetic turbulence inlet
Rij components are ordered as usual: XX, YY, ZZ, XY, YZ, XZ
Arrays are pre-initialized before this function is called (see cs_user_les_inflow_define).
vel_l[face_id][coo_id] = vel_r[coo_id]
rij_l[face_id][0] = 2./3. * k_l rij_l[face_id][1] = 2./3. * k_l rij_l[face_id][2] = 2./3. * k_l rij_l[face_id][3] = 0 rij_l[face_id][4] = 0 rij_l[face_id][5] = 0
eps_l[face_id] = eps_r
[in,out]vel_lvelocity a zone faces
[in,out]rij_lreynods stresses at zone faces
[in,out]eps_lreference turbulent dissipation
◆ cs_user_les_inflow_define()
void cs_user_les_inflow_define ( void  )
◆ cs_user_les_inflow_update()
void cs_user_les_inflow_update ( const cs_zone_t zone,
cs_real_t  vel_r[3],
cs_real_t k_r,
cs_real_t eps_r
◆ synthe()
void synthe ( const cs_real_t *const  ttcabs,
cs_real_t  rcodcl[]
