cs_join_util.c File Reference
#include <errno.h>
#include "fvm_defs.h"
#include "fvm_io_num.h"
#include "cs_join_util.h"
#include "cs_file.h"
#include "cs_order.h"
#include "cs_search.h"
#include "cs_sort.h"
#include "cs_join_set.h"
+ Include dependency graph for cs_join_util.c:
cs_join_t * cs_join_create (int join_number, const char *sel_criteria, float fraction, float plane, fvm_periodicity_type_t perio_type, double perio_matrix[3][4], int verbosity, int visualization, bool preprocessing)
void cs_join_destroy (cs_join_t **join)
cs_join_select_t * cs_join_select_create (const char *selection_criteria, fvm_periodicity_type_t perio_type, int verbosity)
void cs_join_select_destroy (cs_join_param_t param, cs_join_select_t **join_select)
void cs_join_extract_vertices (cs_lnum_t n_select_faces, const cs_lnum_t *select_faces, const cs_lnum_t *f2v_idx, const cs_lnum_t *f2v_lst, cs_lnum_t n_vertices, cs_lnum_t *n_select_vertices, cs_lnum_t *select_vertices[])
void cs_join_clean_selection (cs_lnum_t *n_elts, cs_lnum_t *elts[], cs_lnum_t n_ref_elts, cs_lnum_t ref_elts[])
void cs_join_build_edges_idx (cs_lnum_t n_faces, const cs_lnum_t faces[], const cs_lnum_t f2v_idx[], const cs_lnum_t f2v_lst[], cs_lnum_t v2v_idx[])
void cs_join_build_edges_lst (cs_lnum_t n_faces, const cs_lnum_t faces[], const cs_lnum_t f2v_idx[], const cs_lnum_t f2v_lst[], cs_lnum_t count[], const cs_lnum_t v2v_idx[], cs_lnum_t v2v_lst[])
◆ cs_join_build_edges_idx()
void cs_join_build_edges_idx ( cs_lnum_t  n_faces,
cs_lnum_t  v2v_idx[]
◆ cs_join_build_edges_lst()
void cs_join_build_edges_lst ( cs_lnum_t  n_faces,
cs_lnum_t  count[],
cs_lnum_t  v2v_lst[]
◆ cs_join_clean_selection()
void cs_join_clean_selection ( cs_lnum_t n_elts,
cs_lnum_t elts[],
◆ cs_join_create()
cs_join_t* cs_join_create ( int  join_number,
const char *  sel_criteria,
float  fraction,
float  plane,
int  verbosity,
int  visualization,
bool  preprocessing
◆ cs_join_destroy()
void cs_join_destroy ( cs_join_t **  join)
◆ cs_join_extract_vertices()
void cs_join_extract_vertices ( cs_lnum_t  n_select_faces,
const cs_lnum_t select_faces,
const cs_lnum_t f2v_idx,
const cs_lnum_t f2v_lst,
cs_lnum_t n_select_vertices,
cs_lnum_t select_vertices[]
◆ cs_join_select_create()
cs_join_select_t* cs_join_select_create ( const char *  selection_criteria,
int  verbosity
◆ cs_join_select_destroy()
void cs_join_select_destroy ( cs_join_param_t  param,
cs_join_select_t **  join_select
