cs_iter_algo.c File Reference
Set of routines to handle the management of high-level iterative algorithms such as Uzawa, Golub-Kahan Bi-orthogonalization or Picard algorithms which incorporates inner solvers. More...
#include <float.h>
#include <bft_mem.h>
#include "cs_evaluate.h"
#include "cs_iter_algo.h"
+ Include dependency graph for cs_iter_algo.c:
cs_iter_algo_info_tcs_iter_algo_define (int verbosity, int n_max_iter, double atol, double rtol, double dtol)
 Create and initialize a new cs_iter_algo_info_t structure. More...
void cs_iter_algo_navsto_fb_picard_cvg (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_real_t *pre_iterate, const cs_real_t *cur_iterate, cs_real_t div_l2_norm, cs_iter_algo_info_t *a_info)
 Test if one has to do one more Picard iteration. Test if performed on the relative norm on the increment between two iterations but also on the divergence. More...
◆ cs_iter_algo_define()
cs_iter_algo_info_t* cs_iter_algo_define ( int  verbosity,
int  n_max_iter,
double  atol,
double  rtol,
double  dtol
[in]verbosityset the level of information printed
[in]n_max_itermaximal number of iteration
[in]atolabsolute tolerance
[in]rtolrelative tolerance
[in]dtoldivergence tolerance
a pointer to the new allocated structure
◆ cs_iter_algo_navsto_fb_picard_cvg()
void cs_iter_algo_navsto_fb_picard_cvg ( const cs_cdo_connect_t connect,
const cs_real_t pre_iterate,
const cs_real_t cur_iterate,
cs_iter_algo_info_t a_info
[in]connectset of additional connectivities for CDO
[in]quantset of additional geometrical quantities
[in]pre_iterateprevious state of the mass flux iterate
[in]cur_iteratecurrent state of the mass flux iterate
[in]div_l2_normL2 norm of the velocity divergence
[in,out]a_infopointer to a cs_iter_algo_info_t struct.
