#include <errno.h>
#include <mpi.h>
#include "cs_map.h"
#include "cs_file.h"
#include "cs_timer.h"
#include "cs_io.h"
cs_io_t * | cs_io_initialize (const char *file_name, const char *magic_string, cs_io_mode_t mode, cs_file_access_t method, long echo, MPI_Info hints, MPI_Comm block_comm, MPI_Comm comm) |
cs_io_t * | cs_io_initialize_with_index (const char *file_name, const char *magic_string, cs_file_access_t method, long echo, MPI_Info hints, MPI_Comm block_comm, MPI_Comm comm) |
void | cs_io_finalize (cs_io_t **cs_io) |
const char * | cs_io_get_name (const cs_io_t *cs_io) |
size_t | cs_io_get_index_size (const cs_io_t *inp) |
const char * | cs_io_get_indexed_sec_name (const cs_io_t *inp, size_t id) |
cs_io_sec_header_t | cs_io_get_indexed_sec_header (const cs_io_t *inp, size_t id) |
size_t | cs_io_get_echo (const cs_io_t *cs_io) |
int | cs_io_read_header (cs_io_t *inp, cs_io_sec_header_t *header) |
int | cs_io_set_indexed_position (cs_io_t *inp, cs_io_sec_header_t *header, size_t id) |
void | cs_io_set_int (cs_io_sec_header_t *header, const cs_io_t *cs_io) |
void | cs_io_set_cs_lnum (cs_io_sec_header_t *header, const cs_io_t *cs_io) |
void | cs_io_set_cs_gnum (cs_io_sec_header_t *header, const cs_io_t *cs_io) |
void | cs_io_assert_cs_real (const cs_io_sec_header_t *header, const cs_io_t *cs_io) |
void * | cs_io_read_global (const cs_io_sec_header_t *header, void *elts, cs_io_t *cs_io) |
void * | cs_io_read_block (const cs_io_sec_header_t *header, cs_gnum_t global_num_start, cs_gnum_t global_num_end, void *elts, cs_io_t *cs_io) |
void * | cs_io_read_index_block (cs_io_sec_header_t *header, cs_gnum_t global_num_start, cs_gnum_t global_num_end, cs_gnum_t *elts, cs_io_t *cs_io) |
void | cs_io_write_global (const char *sec_name, cs_gnum_t n_vals, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, const void *elts, cs_io_t *outp) |
void | cs_io_write_block (const char *sec_name, cs_gnum_t n_g_elts, cs_gnum_t global_num_start, cs_gnum_t global_num_end, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, const void *elts, cs_io_t *outp) |
void | cs_io_write_block_buffer (const char *sec_name, cs_gnum_t n_g_elts, cs_gnum_t global_num_start, cs_gnum_t global_num_end, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, void *elts, cs_io_t *outp) |
void | cs_io_skip (const cs_io_sec_header_t *header, cs_io_t *pp_io) |
cs_file_off_t | cs_io_get_offset (cs_io_t *inp) |
void | cs_io_set_offset (cs_io_t *inp, cs_file_off_t offset) |
void | cs_io_log_initialize (void) |
void | cs_io_log_finalize (void) |
void | cs_io_dump (const cs_io_t *cs_io) |
void cs_io_assert_cs_real | ( | const cs_io_sec_header_t * | header, |
const cs_io_t * | cs_io | ||
void cs_io_dump | ( | const cs_io_t * | cs_io | ) |
void cs_io_finalize | ( | cs_io_t ** | cs_io | ) |
size_t cs_io_get_echo | ( | const cs_io_t * | cs_io | ) |
size_t cs_io_get_index_size | ( | const cs_io_t * | inp | ) |
cs_io_sec_header_t cs_io_get_indexed_sec_header | ( | const cs_io_t * | inp, |
size_t | id | ||
const char* cs_io_get_indexed_sec_name | ( | const cs_io_t * | inp, |
size_t | id | ||
const char* cs_io_get_name | ( | const cs_io_t * | cs_io | ) |
cs_file_off_t cs_io_get_offset | ( | cs_io_t * | inp | ) |
cs_io_t* cs_io_initialize | ( | const char * | file_name, |
const char * | magic_string, | ||
cs_io_mode_t | mode, | ||
cs_file_access_t | method, | ||
long | echo, | ||
MPI_Info | hints, | ||
MPI_Comm | block_comm, | ||
MPI_Comm | comm | ||
cs_io_t* cs_io_initialize_with_index | ( | const char * | file_name, |
long | echo, | ||
void cs_io_log_finalize | ( | void | ) |
void cs_io_log_initialize | ( | void | ) |
void* cs_io_read_block | ( | const cs_io_sec_header_t * | header, |
cs_gnum_t | global_num_start, | ||
cs_gnum_t | global_num_end, | ||
void * | elts, | ||
void* cs_io_read_global | ( | const cs_io_sec_header_t * | header, |
void * | elts, | ||
int cs_io_read_header | ( | cs_io_t * | inp, |
cs_io_sec_header_t * | header | ||
void* cs_io_read_index_block | ( | cs_io_sec_header_t * | header, |
cs_gnum_t * | elts, | ||
void cs_io_set_cs_gnum | ( | cs_io_sec_header_t * | header, |
void cs_io_set_cs_lnum | ( | cs_io_sec_header_t * | header, |
int cs_io_set_indexed_position | ( | cs_io_t * | inp, |
cs_io_sec_header_t * | header, | ||
size_t | id | ||
void cs_io_set_int | ( | cs_io_sec_header_t * | header, |
void cs_io_set_offset | ( | cs_io_t * | inp, |
cs_file_off_t | offset | ||
void cs_io_skip | ( | const cs_io_sec_header_t * | header, |
cs_io_t * | pp_io | ||
void cs_io_write_block | ( | const char * | sec_name, |
cs_gnum_t | n_g_elts, | ||
size_t | location_id, | ||
size_t | index_id, | ||
size_t | n_location_vals, | ||
cs_datatype_t | elt_type, | ||
const void * | elts, | ||
cs_io_t * | outp | ||
void cs_io_write_block_buffer | ( | const char * | sec_name, |
void * | elts, | ||
void cs_io_write_global | ( | const char * | sec_name, |
cs_gnum_t | n_vals, | ||
