Include dependency graph for cs_interpolate.h:Go to the source code of this file.
| typedef void() | cs_interpolate_from_location_t(void *input, cs_datatype_t datatype, int val_dim, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], const void *location_vals, void *point_vals) |
| Function pointer for interpolatation of values defined on a mesh location at a given set of points. More... | |
| void | cs_interpolate_from_location_p0 (void *input, cs_datatype_t datatype, int val_dim, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], const void *location_vals, void *point_vals) |
| Interpolate values defined on a mesh location at a given set of points using a P0 interpolation. More... | |
| void | cs_interpolate_from_location_p1 (void *input, cs_datatype_t datatype, int val_dim, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], const void *location_vals, void *point_vals) |
| Interpolate values defined on a mesh location at a given set of points using a P1 interpolation. More... | |
| typedef void() cs_interpolate_from_location_t(void *input, cs_datatype_t datatype, int val_dim, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], const void *location_vals, void *point_vals) |
| [in,out] | input | pointer to optional (untyped) value or structure. |
| [in] | datatype | associated datatype |
| [in] | val_dim | dimension of data values |
| [in] | n_points | number of interpolation points |
| [in] | point_location | location of points in mesh elements |
| [in] | location_vals | values at mesh location |
| [out] | point_vals | interpolated values at points |
| void cs_interpolate_from_location_p0 | ( | void * | input, |
| int | val_dim, | ||
| cs_lnum_t | n_points, | ||
| const cs_lnum_t | point_location[], | ||
| const cs_real_3_t | point_coords[], | ||
| const void * | location_vals, | ||
| void * | point_vals | ||
This function allows unlocated points (with point_location < 0), to which the value 0 is assigned.
(DOXYGEN_SHOULD_SKIP_THIS)
| void cs_interpolate_from_location_p1 | ( | void * | input, |
| int | val_dim, | ||
This function assumes the input is a field name. If no field matches the name, a "generic" interpolation (assuming homogeneous Neumann boundary conditions) is used).
The P1 interpolation is based on a local least-squares gradient, so it is assumed that ghost values of the localtion_vals array are synchronized if present.
If the field's boundary values (i.e. associated field) are known, they are used in the interpolation. Otherwise, if boundary conditions are defined, they are used. When neither boundary values nor boundary conditions are known, homogeneous Neumann boundary conditions are assumed.
