cs_geom.c File Reference
#include <float.h>
#include "cs_math.h"
#include "cs_geom.h"
+ Include dependency graph for cs_geom.c:
void cs_geom_closest_point (cs_lnum_t n_points, const cs_real_t point_coords[][3], const cs_real_t query_coords[3], cs_lnum_t *point_id, int *rank_id)
 find the closest point of a set to a given point in space. More...
double cs_geom_segment_intersect_face (int orient, cs_lnum_t n_vertices, const cs_lnum_t vertex_ids[], const cs_real_t vtx_coord[][3], const cs_real_t face_cog[3], const cs_real_t sx0[3], const cs_real_t sx1[3], int n_inout[2], cs_real_t *face_norm)
 Test if a line segment intersects a face. More...
Geometry utility functions.
◆ cs_geom_closest_point()
void cs_geom_closest_point ( cs_lnum_t  n_points,
cs_lnum_t point_id,
int *  rank_id
If the orient parameter is set to -1 or 1, intersection is only considered when (sx1-sx0).normal.orient > 0. If set to 0, intersection is considered in both cases.
[in]n_pointsnumber of points
[in]point_coordspoint coordinates
[in]query_coordscoordinates searched for
[out]point_idid of closest point if on the same rank, -1 otherwise
[out]rank_idid of rank containing closest point
◆ cs_geom_segment_intersect_face()
double cs_geom_segment_intersect_face ( int  orient,
int  n_inout[2],
cs_real_t face_norm
| x---------------------—|-----—x D: end coordinates O: start coordiantes | x G: Face (Center of Gravity) x current | cell center | | Face number
[in]orientif -1 or 1, multiplies face_normal to check for segment
[in]n_verticesnumber of face vertices
[in]vertex_idsids of face vertices
[in]vtx_coordvertex coordinates
[in]face_cogcoordinates of face center
[in]sx0segment start coordinates
[in]sx1segment end coordinates
[out]n_inoutnumber sub_face crossings [0: in; 1: out]
[in,out]face_normlocal face unit normal of the crossed sub triangle (if entering with something different from NULL)
2 if the segment does not go through the face's plane, or minimum relative distance (in terms of segment length) of intersection point to face.
