bft_mem_usage.h File Reference
+ Include dependency graph for bft_mem_usage.h:
void bft_mem_usage_init (void)
 Initialize memory usage count depending on system. More...
void bft_mem_usage_end (void)
 End memory usage count depending on system. More...
int bft_mem_usage_initialized (void)
 Indicates if bft_mem_usage_...() functions are initialized. More...
size_t bft_mem_usage_pr_size (void)
 Return current process memory use (in kB) depending on system. More...
size_t bft_mem_usage_max_pr_size (void)
size_t bft_mem_usage_max_vm_size (void)
size_t bft_mem_usage_shared_lib_size (void)
void bft_mem_usage_n_calls (size_t count[3])
◆ bft_mem_usage_end()
void bft_mem_usage_end ( void  )
◆ bft_mem_usage_init()
void bft_mem_usage_init ( void  )
This functions checks if it has already been called, so it is safe to call more than once (though it is not thread-safe). Only the first call is effective.
◆ bft_mem_usage_initialized()
int bft_mem_usage_initialized ( void  )
1 if bft_mem_usage_init has been called, 0 otherwise.
◆ bft_mem_usage_max_pr_size()
size_t bft_mem_usage_max_pr_size ( void  )
◆ bft_mem_usage_max_vm_size()
size_t bft_mem_usage_max_vm_size ( void  )
◆ bft_mem_usage_n_calls()
void bft_mem_usage_n_calls ( size_t  count[3])
◆ bft_mem_usage_pr_size()
size_t bft_mem_usage_pr_size ( void  )
If the information is not available (depending on availability of non-portable function calls), 0 is returned.
◆ bft_mem_usage_shared_lib_size()
size_t bft_mem_usage_shared_lib_size ( void  )
