bft_mem.c File Reference
#include <errno.h>
#include "bft_mem_usage.h"
+ Include dependency graph for bft_mem.c:
void bft_mem_init (const char *log_file_name)
 Initialize memory handling. More...
void bft_mem_end (void)
 End memory handling. More...
int bft_mem_initialized (void)
 Indicates if bft_mem_...() functions are initialized. More...
void * bft_mem_malloc (size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
 Allocate memory for ni elements of size bytes. More...
void * bft_mem_realloc (void *ptr, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
 Reallocate memory for ni elements of size bytes. More...
void * bft_mem_free (void *ptr, const char *var_name, const char *file_name, int line_num)
 Free allocated memory. More...
void * bft_mem_memalign (size_t alignment, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
 Allocate aligned memory for ni elements of size bytes. More...
size_t bft_mem_size_current (void)
 Return current theoretical dynamic memory allocated. More...
size_t bft_mem_size_max (void)
 Return maximum theoretical dynamic memory allocated. More...
bft_error_handler_tbft_mem_error_handler_get (void)
 Returns the error handler associated with the bft_mem_...() functions. More...
void bft_mem_error_handler_set (bft_error_handler_t *handler)
 Associates an error handler with the bft_mem_...() functions. More...
int bft_mem_have_memalign (void)
 Indicate if a memory aligned allocation variant is available. More...
Base memory allocation wrappers with optional tracing.
The memory managment function provided here provide optional logging, and tracking of non-freed pointers.
Since in most of the intended applications, failure to allocate memory is considered fatal, failed allocations from these functions are considedered as errors, which are fatal by default but can be handled differently if an appropriate error handler is defined. So additional checking of the return values in the calling code is not needed.
The functions provided here are otherwise based on the matching C library functions.
◆ bft_mem_end()
void bft_mem_end ( void  )
This function should be called after all other bft_mem_...() functions. In case of memory allocation logging, it writes final information to the log file and closes is.
◆ bft_mem_error_handler_get()
bft_error_handler_t* bft_mem_error_handler_get ( void  )
pointer to the error handler function.
◆ bft_mem_error_handler_set()
void bft_mem_error_handler_set ( bft_error_handler_t handler)
With the default error handler, an error message is output to stderr, (after bft_print_flush() is called), and the general error handler used by bft_error() is then called (which results in the termination of the current process or process group).
handlerpointer to the error handler function [in].
◆ bft_mem_free()
void* bft_mem_free ( void *  ptr,
const char *  var_name,
const char *  file_name,
int  line_num
This function calls free(), but adds tracing capabilities, and automatically calls the bft_error() errorhandler if it fails to free the corresponding memory. In case of a NULL pointer argument, the function simply returns.
[in]ptrpointer to previous memory location (if NULL, bft_alloc() called).
[in]var_nameallocated variable name string
[in]file_namename of calling source file
[in]line_numline number in calling source file
NULL pointer.
◆ bft_mem_have_memalign()
int bft_mem_have_memalign ( void  )
If no such function is available, bft_mem_memalign() will always fail.
1 if memory aligned allocation is possible, 0 otherwise.
◆ bft_mem_init()
void bft_mem_init ( const char *  log_file_name)
This function should be called before any other bft_mem_...() function. To activate memory allocation logging, a logfile name should be given as an argument. The resulting file will be a regular, local file. If this file cannot be opened for some reason, logging is silently de-activated.
log_file_namename of optional log_file (if NULL, no log).
◆ bft_mem_initialized()
int bft_mem_initialized ( void  )
1 if bft_mem_init has been called, 0 otherwise.
◆ bft_mem_malloc()
void* bft_mem_malloc ( size_t  ni,
size_t  size,
int  line_num
This function calls malloc(), but adds tracing capabilities, and automatically calls the bft_error() errorhandler if it fails to allocate the required memory.
[in]ninumber of elements.
[in]sizeelement size.
[in]var_nameallocated variable name string.
[in]file_namename of calling source file.
[in]line_numline number in calling source file.
pointer to allocated memory.
◆ bft_mem_memalign()
void* bft_mem_memalign ( size_t  alignment,
size_t  ni,
size_t  size,
int  line_num
This function calls posix_memalign() if available, but adds tracing capabilities, and automatically calls the bft_error() errorhandler if it fails to allocate the required memory.
The associated function bft_mem_have_memalign() indicates if this type of allocation may be used on this system.
[in]alignmentalignment.
◆ bft_mem_realloc()
void* bft_mem_realloc ( void *  ptr,
size_t  ni,
size_t  size,
int  line_num
This function calls realloc(), but adds tracing capabilities, and automatically calls the bft_error() errorhandler if it fails to allocate the required memory.
pointer to reallocated memory.
◆ bft_mem_size_current()
size_t bft_mem_size_current ( void  )
current memory handled through bft_mem_...() (in kB).
◆ bft_mem_size_max()
size_t bft_mem_size_max ( void  )
maximum memory handled through bft_mem_...() (in kB).
