Data Fields
cs_space_disc_t Struct Reference
Space discretisation options descriptor. More...
#include <cs_parameters.h>
Collaboration diagram for cs_space_disc_t:
Collaboration graph
Data Fields
int imvisf
int imrgra
double anomax
int iflxmw
Members of the space discretisation structure are publicly accessible, to allow for concise syntax, as they are expected to be used in many places.
Field Documentation
◆ anomax
anomax
non orthogonality angle of the faces, in radians. For larger angle values, cells with one node on the wall are kept in the extended support of the neighboring cells.
◆ iflxmw
iflxmw
method to compute interior mass flux due to ALE mesh velocity
  • 0: based on nodes displacement
  • 1: based on cell center mesh velocity
◆ imrgra
imrgra
type of gradient reconstruction
  • 0: iterative process
  • 1: standard least squares method
  • 2: least squares method with extended neighborhood
  • 3: least squares method with reduced extended neighborhood
  • 4: iterative process initialized by the least squares method
◆ imvisf
imvisf
face viscosity field interpolation
  • 1: harmonic
  • 0: arithmetic (default)
