| integer, save | nfecra |
| standard output More... | |
| integer, save | impmvo |
| unit of the upstream restart file for the vortex method. Useful if and only if isuivo=1 and ivrtex=1. More... | |
| integer, save | impvvo |
| unit of the downstream restart file for the vortex method. Useful if and only if ivrtex=1. More... | |
| integer, save | impdvo |
| unit of the ficvor data files for the vortex method. More... | |
| character(len=13), save | ficdat |
| name of file, see usvort module. More... | |
| integer, save | ntsuit |
| saving period of the restart filesy5 More... | |
| integer, save | keylbl = -1 |
| field key for output label More... | |
| integer, save | keylog = -1 |
| field key for logging For every quantity (variable, physical or numerical property ...), indicator concerning the writing in the execution report file More... | |
| integer, save | keyvis = -1 |
| field key for postprocessing output. More... | |
| character(len=13), save ficdat |
| integer, save impdvo |
These files are text files. Their number and names are specified by the user in the usvort subroutine. (Although it corresponds to an 'upstream' data file, impdvo is initialized to 20 because, in case of multiple vortex entries, it is opened at the same time as the upstream restart file, which already uses unit 11) useful if and only if ivrtex=1.
| integer, save impmvo |
| integer, save impvvo |
| integer, save keylbl = -1 |
| integer, save keylog = -1 |
| integer, save keyvis = -1 |
Each quantity defined at the cell centres (physical or numerical variable), indicator of whether it should be post-processed or not
k, scalars), density, turbulent viscosity and the time step if is not uniform| integer, save nfecra |
standard output
| integer, save ntsuit |
