Data Types | |
| type | categorie_sol |
| kind of soil (water, forest, urban ...) and associated constantes More... | |
| type | variables_sol |
| Class definition of soil_variables. More... | |
| type | soil_tab |
| Defines the soil constants and variables of the vertical arrays used for the 1D radiative model. More... | |
| integer, save | nfmodsol |
| Number of boundary faces with soil features. More... | |
| integer, save | nbrsol |
| Number of soil model's type. More... | |
| double precision | rugdyn |
| Dynamic roughness length. More... | |
| double precision | rugthe |
| Thermal roughness length. More... | |
| double precision | albedo |
| Albedo. More... | |
| double precision | emissi |
| emissivity More... | |
| double precision | vegeta |
| Vegetation index. More... | |
| double precision | c1w |
| maximum water capacity of shallow reservoir More... | |
| double precision | c2w |
| ratio of the maximum water capacity of the shallow reservoir to the deep reservoir [0,1] More... | |
| double precision | csol |
| Thermal inertia of the soil. More... | |
| double precision | r1 |
| Rij value for Rij1. More... | |
| double precision | r2 |
| Rij value for Rij2. More... | |
| double precision | tprof |
| deep soil temperture More... | |
| character(len=10) | nomcat |
| Soil category name. More... | |
| type(categorie_sol) | constantes |
| double precision | temp_sol |
| soil temperature More... | |
| double precision | tempp |
| deep soil temperature More... | |
| double precision | total_water |
| total water content More... | |
| double precision | w1 |
| ratio of the shallow reservoir water content to its maximum capacity More... | |
| double precision | w2 |
| ratio of the deep reservoir water content to its maximum capacity More... | |
| double precision | tsini |
| initial soil surface temperature More... | |
| double precision | tprini |
| initial deep soil temperature More... | |
| double precision | qvsini |
| initial soil specific humidity More... | |
| double precision | tmer |
| Sea surface temperature. More... | |
| type(categorie_sol), dimension(:), allocatable | tab_sol |
| array of the different features of each soil category More... | |
| integer, dimension(:), allocatable, save | indsol |
| index of boundary faces with soil features More... | |
| integer, dimension(:,:), allocatable | pourcent_sol |
| percentage of soil's category in each boundary face More... | |
| type(variables_sol), dimension(:), allocatable, save | solution_sol |
| Class soil variable dimension. More... | |
| albedo More... | |
| double precision | ttsoil |
| soil thermo temperature More... | |
| double precision | tpsoil |
| soil potential temperature More... | |
| double precision | totwat |
| double precision | pressure |
| surface pressure More... | |
| double precision | density |
| density More... | |
| double precision | foir |
| ir downcoming flux More... | |
| double precision | fos |
| solar radation absorbed by the soil More... | |
| type(soil_tab), dimension(:), allocatable, save | soilvert |
| Class soilvert dimension. More... | |
| double precision albedo |
Albedo.
albedo
| double precision c1w |
| double precision c2w |
| type(categorie_sol) constantes |
| double precision csol |
| double precision density |
density
| double precision emissi |
emissivity
emissivity
| double precision foir |
ir downcoming flux
| double precision fos |
| integer, dimension(:), allocatable, save indsol |
| integer, save nbrsol |
| integer, save nfmodsol |
| character(len=10) nomcat |
Soil category name.
| integer, dimension(:,:), allocatable pourcent_sol |
| double precision pressure |
surface pressure
| double precision qvsini |
| double precision r1 |
Rij value for Rij1.
| double precision r2 |
Rij value for Rij2.
| double precision rugdyn |
| double precision rugthe |
| type(soil_tab), dimension(:), allocatable, save soilvert |
| type(variables_sol), dimension(:), allocatable, save solution_sol |
| type(categorie_sol), dimension(:), allocatable tab_sol |
| double precision temp_sol |
soil temperature
| double precision tempp |
| double precision tmer |
| double precision total_water |
total water content
| double precision totwat |
total water content
| double precision tprini |
| double precision tprof |
| double precision tpsoil |
| double precision tsini |
| double precision ttsoil |
| double precision vegeta |
Vegetation index.
| double precision w1 |
| double precision w2 |
