Properties definition initialization, according to calculation type selected by the user.
More...
| subroutine | fldprp |
| subroutine | add_property_field_1d (name, label, f_id) |
| | add field defining a one-dimensional property field defined on cells, with no previous time values and with default options More...
| subroutine | hide_property (f_id) |
| | disable logging and postprocessing for a property field More...
| subroutine | add_property_field (name, label, dim, has_previous, f_id) |
| | add field defining a property field defined on cells, with default options More...
| subroutine | add_boundary_property_field_owner (name, label, f_id) |
| | add owner field defining a property field defined on boundary faces, with default options More...
◆ add_boundary_property_field_owner()
| subroutine add_boundary_property_field_owner |
character(len=*), intent(in) |
name, |
label, |
integer, intent(out) |
f_id |
It is recommended not to define property names of more than 16 characters, to get a clear execution log (some advanced writing levels take into account only the first 16 characters).
- Parameters
| [in] | name | field name |
| [in] | label | field default label, or empty |
| [out] | f_id | matching field id |
◆ add_property_field()
| subroutine add_property_field |
name, |
label, |
integer, intent(in) |
dim, |
logical, intent(in) |
has_previous, |
f_id |
- Parameters
| [in] | dim | field dimension |
| [in] | has_previous | indicates if the field also has previous time step values |
◆ add_property_field_1d()
| subroutine add_property_field_1d |
name, |
label, |
f_id |
- Parameters
| [out] | f_id | field id |
◆ fldprp()
◆ hide_property()
| subroutine hide_property |
f_id | ) |
- Parameters
