Module for input/output. More...
Modules | |
| module | entsor |
Functions/Subroutines | |
| subroutine | flush_nfecra () |
| Flush Fortran log. More... | |
| subroutine | listing_writing_period_init |
| Map ntlist from C to Fortran. More... | |
| integer, save | nfecra |
| standard output More... | |
| integer, save | impmvo |
| unit of the upstream restart file for the vortex method. Useful if and only if isuivo=1 and ivrtex=1. More... | |
| integer, save | impvvo |
| unit of the downstream restart file for the vortex method. Useful if and only if ivrtex=1. More... | |
| integer, save | impdvo |
| unit of the ficvor data files for the vortex method. More... | |
| character(len=13), save | ficdat |
| name of file, see usvort module. More... | |
| integer, save | ntsuit |
| saving period of the restart filesy5 More... | |
| integer, save | keylbl = -1 |
| field key for output label More... | |
| integer, save | keylog = -1 |
| field key for logging For every quantity (variable, physical or numerical property ...), indicator concerning the writing in the execution report file More... | |
| integer, save | keyvis = -1 |
| field key for postprocessing output. More... | |
| character(len=32), save | ficfpp |
| name of the thermochemical data file for combustion. More... | |
| integer, save | impfpp |
| logical unit of the thermochemical data file. Useful in case of gas or pulverized coal combustion or electric arcs; More... | |
| integer, save | indjon |
| use Janaf (=1) or not (=0) More... | |
| character(len=32), save | ficmet |
| Input files for the atmospheric specific physics (name of the meteo profile file) More... | |
| integer, save | impmet |
| logical unit of the meteo profile file More... | |
| character(len=80), save | emphis |
| directory in which the potential chronological record files generated by the Kernel will be written (path related to the execution directory) More... | |
| character(len=80), save | prehis |
| prefix of history files More... | |
| integer, dimension(2), save | impsth |
| mobile structure variables output unit More... | |
| integer, save | tplfmt |
| time plot format (1: .dat, 2: .csv, 3: both) More... | |
| integer, save | nthist |
| output period of the chronological record files: More... | |
| double precision, save | frhist |
| frhist : output frequency in seconds More... | |
| integer, save | ihistr |
| write indicator (O or 1) for history of internal mobile structures More... | |
| integer | nusrmx |
| maximal number of user files More... | |
| integer, dimension(nusrmx), save | impusr |
| unit numbers for potential user specified files. Useful if and only if the user needs files (therefore always useful, by security) More... | |
| character(len=80), save | nomva0 |
| temporary variable name for some algebraic operations More... | |
| integer(c_int), pointer, save | ntlist |
| writing period in the execution report file. More... | |
| integer, dimension(5), save | ipstdv |
indicates the data to post-process on the boundary mesh (the boundary mesh must be associated with an active writer). ipstdv(key) indicates which fields should be created and output on the boundary, with key in ipstfo, ipstyp, ipsttp, ipstft, ipstnu. More... | |
| integer | ipstfo |
| post-processed property: Efforts (0: none 1: all; 2: tangent; 4: normal) More... | |
| integer | ipstyp |
post-processed property: at the boundary More... | |
| integer | ipsttp |
post-processed property : at the boundary More... | |
| integer | ipstft |
post-processed property: thermal flux at the boundary (in ), More... | |
| integer | ipstnu |
| post-processed property: Nusselt More... | |
