381 const int *diffusion,
386 const int *unsaturated);
521 const char *property_name,
void cs_gui_profile_output(void)
Definition: cs_gui.c:4435
void csidtv(void)
Definition: cs_gui.c:1886
double precision, save viscv0
reference volume viscosity (noted in the equation expressing in the paragraph dedicated to iviscv) ...
Definition: ppincl.f90:623
#define restrict
Definition: cs_defs.h:127
void csnum2(double *relaxp, double *extrag, int *imrgra)
Definition: cs_gui.c:2180
void cs_gui_user_variables(void)
Definition: cs_gui.c:5102
void cs_gui_head_losses(const cs_zone_t *zone, const cs_real_3_t *cvara_vel, cs_real_t cku[][6])
Compute GUI-defined head losses for a given volume zone.
Definition: cs_gui.c:4021
void cs_gui_fluid_properties_value(const char *param, double *value)
Definition: cs_gui.c:4788
void cscfgp(int *icfgrp)
Definition: cs_gui.c:1937
void csisui(int *ntsuit, int *ileaux, int *iccvfg)
Definition: cs_gui.c:1965
integer iesder
Error estimator for Navier-Stokes. iest = iesder: drift (default name: EsDer). The estimator is base...
Definition: paramx.f90:258
integer, save ntsuit
saving period of the restart filesy5
Definition: entsor.f90:72
void cssca3(double *visls0)
Definition: cs_gui.c:2447
Definition: cs_defs.h:467
int cs_int_t
Fortran-compatible integer.
Definition: cs_defs.h:301
void cs_gui_turbomachinery(void)
Definition: cs_gui.c:4965
void cs_gui_define_fans(void)
Definition: cs_gui.c:5389
void cs_gui_parallel_io(void)
Definition: cs_gui.c:4238
void cs_gui_user_arrays(void)
Definition: cs_gui.c:5162
integer idarcy
pointer to specify richards model
Definition: ppincl.f90:238
void cs_gui_turb_ref_values(void)
Definition: cs_gui.c:1703
int cs_gui_thermal_model(void)
Definition: cs_gui.c:4806
void cssca2(int *iturt)
Definition: cs_gui.c:2368
Definition: cs_defs.h:302
integer, save isuite
Indicator of a calculation restart (=1) or not (=0). This value is set automatically by the code; dep...
Definition: optcal.f90:312
void cs_gui_usage_log(void)
Definition: cs_gui.c:5074
void cs_gui_partition(void)
Definition: cs_gui.c:4306
void uiporo(void)
Definition: cs_gui.c:2532
void cs_gui_turbomachinery_rotor(void)
Definition: cs_gui.c:4980
void cscpva(void)
Definition: cs_gui.c:1748
void csphys(double *viscv0, double *visls0, const int *itempk)
Definition: cs_gui.c:2209
integer(c_int), pointer, save iccvfg
Definition: optcal.f90:853
void csther(void)
Definition: cs_gui.c:1567
void uiexop(void)
Definition: cs_gui.c:3512
void csivis(void)
Definition: cs_gui.c:1812
void cs_gui_properties_value_by_fluid_id(const int fluid_id, const char *property_name, double *value)
Definition: cs_gui.c:4752
void cs_gui_zones(void)
Definition: cs_gui.c:5199
void uitssc(const int *idarcy, const int *f_id, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp)
Definition: cs_gui.c:2728
double precision, dimension(nscamx), save visls0
reference molecular diffusivity related to the scalar J ( ).
Definition: optcal.f90:1185
integer, save icfgrp
indicates if the boundary conditions should take into account (=1) or not (=0) the hydrostatic balanc...
Definition: ppincl.f90:663
integer, dimension(nestmx), save iescal
iescal indicates the calculation mode for the error estimator iespre, iesder, iescor or iestot for th...
Definition: optcal.f90:994
void uiphyv(const cs_int_t *iviscv, const cs_int_t *itempk, const cs_real_t *visls0, const cs_real_t *viscv0)
Definition: cs_gui.c:3338
void cs_gui_pressure_drop_by_zone(void)
Definition: cs_gui.c:5367
integer, save itempk
temperature deduced from the specific total energy
Definition: ppincl.f90:560
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:315
void cs_gui_error_estimator(int *iescal, int *iespre, int *iesder, int *iescor, int *iestot)
Definition: cs_gui.c:5457
double precision, dimension(nvarmx), save cdtvar
multiplicator coefficient for the time step of each variable
Definition: optcal.f90:480
void cs_gui_properties_value(const char *property_name, double *value)
Definition: cs_gui.c:4726
void uidapp(const int *permeability, const int *diffusion, const int *gravity, const cs_real_t *gravity_x, const cs_real_t *gravity_y, const cs_real_t *gravity_z, const int *unsaturated)
Definition: cs_gui.c:3534
void uitsth(const int *f_id, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp)
Definition: cs_gui.c:2815
void uieres(int *iescal, int *iespre, int *iesder, int *iescor, int *iestot)
Definition: cs_gui.c:3923
void uifans(void)
Definition: cs_gui.c:3908
Definition: cs_defs.h:468
void cs_gui_finalize(void)
Definition: cs_gui.c:3959
integer, save ileaux
Indicates the reading (=1) or not (=0) of the auxiliary calculation restart file Useful only in the ...
Definition: optcal.f90:317
#define CS_PROCF(x, y)
Definition: cs_defs.h:481
void uitsnv(const cs_real_3_t *restrict vel, cs_real_3_t *restrict tsexp, cs_real_33_t *restrict tsimp)
Definition: cs_gui.c:2611
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:321
void csvvva(int *iviscv)
Definition: cs_gui.c:1773
void cs_gui_init(void)
Definition: cs_gui.c:3941
integer, dimension(nscamx), save iturt
turbulent flux model for for any scalar , iturt(isca)
Definition: optcal.f90:787
void cs_gui_add_notebook_variables(void *ev_law)
Add notebook variable to a formula.
Definition: cs_gui.c:3984
void csiphy(void)
Definition: cs_gui.c:1910
void cstime(void)
Definition: cs_gui.c:1994
void cs_gui_turb_model(void)
Definition: cs_gui.c:1607
void cs_gui_time_moments(void)
Definition: cs_gui.c:4840
void cs_gui_porous_model(void)
Definition: cs_gui.c:4405
integer, save iviscv
additional property:
Definition: ppincl.f90:600
void uiiniv(const int *isuite, const int *idarcy, int *iccfth)
Definition: cs_gui.c:2896
void uithsc(void)
Definition: cs_gui.c:1795
integer iestot
Error estimator for Navier-Stokes. iest = iestot: total, (default name: EsTot). The estimator ...
Definition: paramx.f90:308
integer iescor
Error estimator for Navier-Stokes. iest = iescor: correction, (default name: EsCor). The estimator comes directly from the mass flow calculated with the updated velocity field: .
Definition: paramx.f90:278
integer(c_int), pointer, save imrgra
type of gradient reconstruction
Definition: optcal.f90:286
void cs_gui_linear_solvers(void)
Definition: cs_gui.c:4094
void cs_gui_balance_by_zone(void)
Definition: cs_gui.c:5338
void uinum1(double *cdtvar)
Definition: cs_gui.c:2067
integer iespre
Error estimator for Navier-Stokes. iest = iespre: prediction, (default name: EsPre). After the velocity prediction step (yielding ), the estimator , local variable calculated at every cell , is created from , which represents the residual of the equation solved during this step: and : .
Definition: paramx.f90:242
