| integer | nmodmx |
| number of specific physics More... | |
| integer(c_int), dimension(:), pointer, save | ippmod |
| global indicator for speciphic physics By default, all the indicators ippmod(i.....) are initialized to -1, which means that no specific physics is activated. More... | |
| integer | iphpar |
| ippmod(iphpar) is a global indicator for the specific physics: More... | |
| integer | icod3p |
| pointer for specific physics More... | |
| integer | icoebu |
| pointer to specify Eddy Break Up pre-mixed flame with indicator ippmod(icoebu) More... | |
| integer | icolwc |
| pointer to specify Libby-Williams pre-mixed flame withy indicator ippmod(icolwc) More... | |
| integer(c_int), pointer, save | isoot |
| integer | ieljou |
| pointer to specify Joule effect module (Laplace forces not taken into account) with indicator ippmod(ieljou): More... | |
| integer | ielarc |
| pointer to specify Electric arcs module (Joule effect and Laplace forces) with indicator ippmod(ielarc): More... | |
| integer | icpl3c |
| pointer to specify Lagrangian modelling of multi-coals and multi-classes pulverised coal combustion with indicator ippmod(icpl3c). The number of different coals must be inferior or equal to ncharm = 3. The number of particle size classes nclpch(icha) for the coal icha, must be inferior or equal to ncpcmx = 10. More... | |
| integer | iccoal |
| pointer to specify multi-coals and multi-classes pulverised coal combustion with indicator ippmod(iccoal). The number of different coals must be inferior or equal to ncharm = 3. The number of particle size classes nclpch(icha) for the coal icha, must be inferior or equal to ncpcmx = 10. More... | |
| integer | i_comb_drift |
| coal with drift (0: without drift (default), 1: with) More... | |
| integer | icfuel |
| pointer to specify multi-classes pulverised heavy fuel combustion with indicator ippmod(icfuel) More... | |
| integer | icompf |
| pointer to specify compressible module with indicator ippmod(icompf) More... | |
| integer | iatmos |
| pointer to specify atmospheric flow module with indicator ippmod(iatmos) More... | |
| integer | iaeros |
| pointer to specify cooling towers module with indicator ippmod(iaeros) More... | |
| integer | igmix |
| pointer to specify gas mixture module with indicator ippmod(igmix) More... | |
| integer | idarcy |
| pointer to specify richards model More... | |
| integer i_comb_drift |
| integer iaeros |
| integer iatmos |
| integer iccoal |
| integer icfuel |
| integer icod3p |
| integer icoebu |
| integer icolwc |
| integer icompf |
| integer icpl3c |
| integer idarcy |
| integer ielarc |
| integer ieljou |
| integer igmix |
| integer iphpar |
| integer(c_int), dimension(:), pointer, save ippmod |
Multi-classes pulverised heavy fuel combustion: indicator ippmod(icfuel)
Lagrangian modelling of multi-coals and multi-classes pulverised coal combustion: indicator ippmod(icpl3c) The number of different coals must be inferior or equal to ncharm = 3. The number of particle size classes nclpch(icha) for the coal icha, must be inferior or equal to ncpcmx = 10.
Electric arcs module (Joule effect and Laplace forces): indicator ippmod(ielarc)
Joule effect module (Laplace forces not taken into account): indicator ippmod(ieljou)
compressible flow module: indicator ippmod(icompf)
atmospheric flow module: indicator ippmod(iatmos)
| integer(c_int), pointer, save isoot |
| integer nmodmx |
