| void | permas (const cs_int_t *iappel, cs_real_t rom[]) |
| void | perinr (const cs_int_t *const imrgra, const cs_int_t *const iwarnp, const cs_real_t *const epsrgp, const cs_real_t *const extrap) |
| void | cs_gradient_perio_initialize (void) |
| Initialize gradient rotational periodicity computation API. More... | |
| void | cs_gradient_perio_finalize (void) |
| Finalize gradient rotational periodicity computation API. More... | |
| void | cs_gradient_perio_update_mesh (void) |
| Update gradient rotational periodicity computation API in case of mesh modification. More... | |
| void | cs_gradient_perio_init_rij (const cs_field_t *f, int *tr_dim, cs_real_3_t grad[]) |
| Initialize ghost cell values for Reynolds stress tensor gradient. More... | |
| void | cs_gradient_perio_init_rij_tensor (int *tr_dim, cs_real_63_t grad[]) |
| void | cs_gradient_perio_process_rij (const cs_int_t *f_id, cs_real_3_t grad[]) |
| Process grad buffers in case of rotation on Reynolds stress tensor. More... | |
| void cs_gradient_perio_finalize | ( | void | ) |
| void cs_gradient_perio_init_rij | ( | const cs_field_t * | f, |
| int * | tr_dim, | ||
| cs_real_3_t | grad[] | ||
We retrieve the gradient given by perinr (phyvar) for the Reynolds stress tensor in a buffer on ghost cells. then we define dpdx, dpdy and dpdz gradient (1 -> n_cells_with_ghosts).
We can't implicitly take into account rotation of a gradient of a tensor variable because we have to know all components.
We set idimtr to 2 for the Reynolds stress tensor.
We assume that is correct to treat periodicities implicitly for the other variables when reconstructing gradients.
| [out] | tr_dim | 2 for tensor (Rij) in case of rotation, 0 otherwise |
| [in,out] | grad | gradient of field |
| void cs_gradient_perio_init_rij_tensor | ( | int * | tr_dim, |
| cs_real_63_t | grad[] | ||
| void cs_gradient_perio_initialize | ( | void | ) |
| void cs_gradient_perio_process_rij | ( | const cs_int_t * | f_id, |
We retrieve the gradient given by cs_gradient_perio_init_rij (phyvar) for the Reynolds stress tensor in a buffer on ghost cells. Then we define grad gradient (1 -> n_cells_with_ghosts).
parameters: f_id <– field index grad –> gradient of field
size of _drdxyz and _wdrdxy = n_ghost_cells*6*3
| [in] | f_id | field index |
| void cs_gradient_perio_update_mesh | ( | void | ) |
| void perinr | ( | const cs_int_t *const | imrgra, |
| const cs_int_t *const | iwarnp, | ||
| const cs_real_t *const | epsrgp, | ||
| const cs_real_t *const | extrap | ||
