| int | cs_variable_cdo_field_create (const char *name, const char *label, int location_id, int dim, int has_previous) |
| | Add a field shared between CDO and legacy schemes. This field is related to a general solved variable, with default options. More...
| int | cs_variable_field_create (const char *name, const char *label, int location_id, int dim) |
| | Add field defining a general solved variable, with default options. More...
◆ cs_variable_cdo_field_create()
| int cs_variable_cdo_field_create |
const char * |
name, |
const char * |
label, |
int |
location_id, |
int |
dim, |
int |
has_previous |
- Parameters
| [in] | name | field name |
| [in] | label | field default label, or empty |
| [in] | location_id | id of associated location |
| [in] | dim | field dimension |
| [in] | has_previous | no if lower than 1 |
- Returns
- newly defined field id
◆ cs_variable_field_create()
| int cs_variable_field_create |
const char * |
name, |
const char * |
label, |
int |
location_id, |
int |
dim |
- Parameters
- Returns
