cs_field_default.h
1 #ifndef __CS_FIELD_DEFAULT_H__
2 #define __CS_FIELD_DEFAULT_H__
5  * Field utility functions.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
49  * Global variables
51
52 /*=============================================================================
53  * Public function prototypes
55
56 /*----------------------------------------------------------------------------*/
69 /*----------------------------------------------------------------------------*/
70
71 int
72 cs_variable_cdo_field_create(const char *name,
73  const char *label,
74  int location_id,
75  int dim,
76  int has_previous);
77
78 /*----------------------------------------------------------------------------*/
89 /*----------------------------------------------------------------------------*/
90
91 int
92 cs_variable_field_create(const char *name,
93  const char *label,
94  int location_id,
95  int dim);
96
98
100
101 #endif /* __CS_FIELD_DEFAULT_H__ */
Definition: cs_defs.h:467
int cs_variable_field_create(const char *name, const char *label, int location_id, int dim)
Add field defining a general solved variable, with default options.
Definition: cs_field_default.c:178
Definition: cs_defs.h:468
int cs_variable_cdo_field_create(const char *name, const char *label, int location_id, int dim, int has_previous)
Add a field shared between CDO and legacy schemes. This field is related to a general solved variable...
Definition: cs_field_default.c:126
