| void | cs_balance_by_zone_compute (const char *scalar_name, cs_lnum_t n_cells_sel, const cs_lnum_t cell_sel_ids[], cs_real_t balance[CS_BALANCE_N_TERMS]) |
| Compute the different terms of the balance of a given scalar, on a volume zone defined by selected cell ids/. More... | |
| void | cs_balance_by_zone (const char *selection_crit, const char *scalar_name) |
| Compute and log the different terms of the balance of a given scalar, on a volumic zone defined by selection criteria. The different contributions to the balance are printed in the run_solver.log. More... | |
| void | cs_pressure_drop_by_zone_compute (cs_lnum_t n_cells_sel, const cs_lnum_t cell_sel_ids[], cs_real_t balance[CS_BALANCE_P_N_TERMS]) |
| Computes one term of the head loss balance (pressure drop) on a on a volume zone defined by selected cell ids/. More... | |
| void | cs_pressure_drop_by_zone (const char *selection_crit) |
| Computes one term of the head loss balance (pressure drop) on a volumic zone defined by the criterion also given as argument. The different contributions are printed in the run_solver.log. More... | |
| void | cs_surface_balance (const char *selection_crit, const char *scalar_name, const cs_real_t normal[3]) |
| Compute the surface balance of a given scalar. More... | |
| void | cs_flux_through_surface (const char *scalar_name, const cs_real_t normal[3], cs_lnum_t n_b_faces_sel, cs_lnum_t n_i_faces_sel, const cs_lnum_t b_face_sel_ids[], const cs_lnum_t i_face_sel_ids[], cs_real_t *balance, cs_real_t *flux_b_faces, cs_real_t *flux_i_faces) |
| Get the face by face surface flux of a given scalar, through a surface area defined by the given face ids. More... | |
| enum cs_balance_p_term_t |
Pressure drop balance terms
| enum cs_balance_term_t |
Balance terms
| void cs_balance_by_zone | ( | const char * | selection_crit, |
| const char * | scalar_name | ||
This function computes the balance relative to a given scalar on a selected zone of the mesh. We assume that we want to compute balances (convective and diffusive) at the boundaries of the calculation domain represented below (with different boundary types).
The scalar and the zone are selected at the top of the routine by the user. In the case of the temperature, the energy balance in Joules will be computed by multiplying by the specific heat.
| [in] | selection_crit | zone selection criterion |
| [in] | scalar_name | scalar name |
| void cs_balance_by_zone_compute | ( | const char * | scalar_name, |
| cs_lnum_t | n_cells_sel, | ||
| const cs_lnum_t | cell_sel_ids[], | ||
| cs_real_t | balance[CS_BALANCE_N_TERMS] | ||
| [in] | n_cells_sel | number of selected cells |
| [in] | cell_sel_ids | ids of selected cells |
| [out] | balance | array of computed balance terms (see cs_balance_term_t) |
| void cs_flux_through_surface | ( | const char * | scalar_name, |
| const cs_real_t | normal[3], | ||
| cs_lnum_t | n_b_faces_sel, | ||
| cs_lnum_t | n_i_faces_sel, | ||
| const cs_lnum_t | b_face_sel_ids[], | ||
| const cs_lnum_t | i_face_sel_ids[], | ||
| cs_real_t * | balance, | ||
| cs_real_t * | flux_b_faces, | ||
| cs_real_t * | flux_i_faces | ||
For interior faces, the flux is counted negatively relative to the given normal (as neighboring interior faces may have differently-aligned normals).
For boundary faces, the flux is counted negatively in the outwards-facing direction.
| [in] | normal | outwards normal direction |
| [in] | n_b_faces_sel | number of selected boundary faces |
| [in] | n_i_faces_sel | number of selected internal faces |
| [in] | b_face_sel_ids | ids of selected boundary faces |
| [in] | i_face_sel_ids | ids of selected internal faces |
| [out] | balance | optional array of computed balance terms (see cs_balance_term_t), of size CS_BALANCE_N_TERMS, or NULL |
| [out] | flux_b_faces | optional surface flux through selected boundary faces, or NULL |
| [out] | flux_i_faces | optional surface flux through selected interior faces, or NULL |
| void cs_pressure_drop_by_zone | ( | const char * | selection_crit | ) |
| void cs_pressure_drop_by_zone_compute | ( | cs_lnum_t | n_cells_sel, |
| cs_real_t | balance[CS_BALANCE_P_N_TERMS] | ||
| [out] | balance | array of computed balance terms (see cs_balance_p_term_t) |
| void cs_surface_balance | ( | const char * | selection_crit, |
| const char * | scalar_name, | ||
| const cs_real_t | normal[3] | ||
