#include "cs_defs.h"#include <assert.h>#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft_printf.h"#include "bft_error.h"
| void | bft_error (const char *const file_name, const int line_num, const int sys_error_code, const char *const format,...) |
| Calls the error handler (set by bft_error_handler_set() or default). More... | |
| bft_error_handler_t * | bft_error_handler_get (void) |
| Returns the error handler associated with the bft_error() function. More... | |
| void | bft_error_handler_set (bft_error_handler_t *const handler) |
| Associates an error handler with the bft_error() function. More... | |
| void bft_error | ( | const char *const | file_name, |
| const int | line_num, | ||
| const int | sys_error_code, | ||
| const char *const | format, | ||
With the default error handler, bft_print_flush() is called, an error message is output to stderr, and the current process exits with an EXIT_FAILURE code.
| [in] | file_name | name of source file from which error handler called. |
| [in] | line_num | line of source file from which error handler called. |
| [in] | sys_error_code | error code if error in system or libc call, 0 otherwise. |
| [in] | format | format string, as printf() and family. |
| [in] | ... | variable arguments based on format string. |
| bft_error_handler_t* bft_error_handler_get | ( | void | ) |
| void bft_error_handler_set | ( | bft_error_handler_t *const | handler | ) |
| [in] | handler | pointer to the error handler function. |
