Does anyone know how to export a mesh from Fluent and import it to CS?
How to export a mesh from Fluent and import it to CS?
Re: How to export a mesh from Fluent and import it to CS?
If you are using Gambit, then just export the mesh in the (default) neutral format. Code_Saturne preprocessor can read this mesh format.
David
David
David is absolutely right. I use Gambit to genrate meshes (neutral format)
