Y+ problem in Code Saturne 1.3.3
Posted: Tue Jul 26, 2011 2:00 pm
by Sébastien Thomas
Hello every body,
I work to measure Y+ on all cells of a profile, like a cylinder, in Code Saturne 1.3.3.
I have wrote the subroutine usproj which I join but i have the error message :
usproj.F gfortran -D_CS_HAVE_XML -D_CS_LANG_FR -I. -O1 -c usproj.F
In file usproj.F:558
YPLUS(IEL) = RA(IYPPAR+IEL-1) 1
Error: Unexpected STATEMENT FUNCTION statement at (1)
In file usproj.F:586
& CDGFBO(3, IFAC), YPLUS(IEL)
1
Error: Function 'yplus' at (1) has no IMPLICIT type
Can you help me please? In fact, I have different tests with Code Saturne and verify the function with the users' guide but I have'nt the solution.
Thanks you everybody
Sebastien
Re: Y+ problem in Code Saturne 1.3.3
Posted: Tue Jul 26, 2011 3:32 pm
by James McNaughton
You can have a maximum of 72 characters per line in FORTRAN77 so the YPLUS(NFABOR) variable is not recognised. Put it on a new line such as:
If you use something like vi to view the file it will highlight when you go over the max number of characters on a line.
Also you define YPLUS to be the size of NFABOR (number boundary faces) but later refer to it with IEL (cell-id), it's quite probable this will lead to errors. I think you should refer to it as YPLUS(IFAC).
Hope that helps,
James
Posted: Wed Jul 27, 2011 9:18 am
by Sébastien Thomas
Thank you for your answer.
I resolved the problem of implicit and function. But I have a new problem. When I exxecute my case on Code Saturne on 1 proc on my desktop computer, i have a message : ERREUR WHILE RUNNING THE KERNEL (SOLVER). I join my subroutine and the error file and the listing file.
Sebastien
Posted: Wed Jul 27, 2011 1:52 pm
by Mickael Hassanaly
Hello Sebastien,
FINDPT function isn't properly filled line 565 in your usproj.f90.
Mickaël Hassanaly
Posted: Wed Jul 27, 2011 2:55 pm
by Sébastien Thomas
Thank you very much
Sebastien Thomas
Posted: Tue Sep 06, 2011 8:07 am
by Sébastien Thomas
ello every body,
I work to measure Y+ on all cells of a profile NACA and on a cylinder, in Code Saturne 1.3.3.
I wrote the subroutine USPROJ.F which is joined.
This subroutine run but, I have problem when I interpret my results because I notice the value zero for some points but in paraview they have not this value.
Can you help me please? I attach my subroutine usprof and an exemple of results file, Y+
Posted: Thu Sep 08, 2011 10:43 am
Do you run your case on multiple processors?
Mickaël
