Electric module and mixed gases
Jonathan Mougenot
Post by Jonathan Mougenot »
I'm using electric module of Code_Saturne 2.0.1 with mixed gases.
Two different no-reactive gases at 10000 K are injected in a tube. There are not current and not radiation loss. When gases are mixed, the temperature doesn't remain at 10000K (there are +/- 7%).
Have you got any ideas about this problem ? May I use enthalpy correction or numerical correction in terms sources ?
Thank you for your help,
Jonathan
Mickael Hassanaly
Re: Electric module and mixed gases
Post by Mickael Hassanaly »
Could you post you set up (mesh+xml files+routines)?
Mickaël
Jonathan Mougenot
Thanks you for your interest. I post mesh, routines and thermodynamic data.
Jonathan
Mixed.zip
(1.12 MiB) Downloaded 262 times
Mickael Hassanaly
Could you describe precisely what you are expecting to do? Because so far away, it doesn't seem me to be a non correct result but it's hard to say.
Mickaël
