Sorry to bother you again, I have a few more questions about the turbulence models, more particularly about the Rij models and the k-epsilon linear production model.
- Is there any case where one prefer to use one of them? You told me that the k-epsilon linear production was used for jet-impacting flows, but what about the Rij models? And is there any reason if the LRR is rarely used?
- What is the difference between the two k-epsilon models?
Thank you,
Stéphane
Questions regarding the use of Code_Saturne: turbulence models
Alexandre Douce
Re: Questions regarding the use of Code_Saturne: turbulence models
Indeed, "k-eps linear production" is suitable for jet-impacting flows (in fact the flow near a stagnation point), unlike the standard k-eps. But of course RSM can handle jet-impacting flows, but it is more costly in CPU time.
More generally, RSM respond correctly to streamline curvature like rotating flows, flow near a stagnation point, flows affected of buoyancy, computational domain with strong curvature of the boundary wall...
RSM LRR is a legacy model (1975), kept for backward compatibility, prefer the more recent RSM SSG (1991).
Stéphane Blanchet
Thank you for your answers! You used RSM instead of Rij, does it mean Rij-LRR (or SSG) is the same model as the RSM LRR (or SSG) model used in Fluent. I tought the RSM LRR model used in Fluent was a low-Re model, whereas the Rij-eps LRR is a high-Re model in Code_Saturne.
Alexandre Douce
For me, RSM (Reynolds Stress Model) stands for Rij-eps. For Fluent, I don't know, but in Code_Saturne, Rij-eps LRR and Rij-eps SSG are both high Reynolds model. The low Reynolds turbulence model of Code_Saturne is the v2f model.
