Hi all,
I tried to restart a k-omega simulation using the wale model with the version 2.0.0-rc1 and it doesn't work.
I used the GUI to write all the journal-file.xml.
The error file is the following.
cs_gui.c:2629: Fatal error.
Invalid turbulence model: LES_WALE.
1: 0x2b4f370846aa <csturb_+0x29a> (libsaturne.so.0)
2: 0x2b4f3717ef0a <iniusi_+0x76> (libsaturne.so.0)
3: 0x2b4f3717eb1b <initi1_+0x1b> (libsaturne.so.0)
4: 0x2b4f3701af75 <cs_run+0xa5> (libsaturne.so.0)
5: 0x2b4f3701b9d5 <main+0x1f5> (libsaturne.so.0)
6: 0x3363e1d8b4 <__libc_start_main+0xf4> (libc.so.6)
7: 0x40a229 ? (?)
I had done a restart with the dynamic LES model and it works
Is there something special to do with the wale model?
Thank you in advance.
Sylvain
Wale model on 2.0.0-rc1
Re: Wale model on 2.0.0-rc1
it is a known bug, and it is corrected in the 2.0 of Code_Saturne. Thank you for your feedback.
