boundary conditions error.
Chebli Rezki
Post by Chebli Rezki »
I use SALOME code to create and mesh foil geometry. I divided the geometry to two domains: one is the near-foil domain, in which structured finer mesh is applied; the other is the far-from-foil domain (cube in which I could insert the volume around the foil), in which the tetrahedral mesh is applied and element size can be slightly bigger. I meshed each domain only, and I resembled two domains in using "Build Compound" option from SALOME mesh module. I use 2.0.0-rc1 version, I placed the boundary conditions and I launched the calculation.
During calculation I have an error from boundary condition . Indeed, this error concerns interface between the two domains (faces common between the two domains) which I must impose a boundary condition. Please, which is the type of the boundary condition that I can impose in this interface.
Thank you for help.
Best regards.
Rezki
listing-08261231.txt
(24.65 KiB) Downloaded 435 times
Alexandre Douce
Re: boundary conditions error.
Post by Alexandre Douce »
It seems that you have in fact two computational domains for a single instance of Code_Saturne.
Perhaps could you join these two domains in order to remove these "internal" boundary faces ? Try to check th "join meshes" option in the GUI.
