Pressure integration on surfaces
Marie Pomarède
Post by Marie Pomarède »
we study the fluid flow in a cylindrical pipe at Re=1.76e5. The first extremity is the inlet and the other is the outlet. The turbulence model are the k-epsilon and the k-omegaSST, y+ is y+ = 2.381. The aim is to determine the head looses in the pipe in doing the substraction between outlet and inlet pressure surface integration.
We use a CGNS mesh and the Code_Saturne version is 2.0.1.
To calculate those head looses, we first used : PROPFB(IFAC,IPR(IPHAS)), but the results are bad compared with the CFX and WinDP's results (the values are very inferior). Thus we tried to use PROPFB(IFAC,IPRTOT(IPHAS)), in order to calculate the total pressure integral (maybe the head loss is leaded with total pressure in CFX) but the values are the same than with PROBFB(IFAC,IPR(IPHAS)).
So maybe the integer musn't be calculated by PROPFB?
Did anybody make such a calculation in usproj.f90 ?
We join our usproj.f90 : maybe someone could give us help about our mistake !
Pauline Delteil & Marie Pomarède
usproj_conduite.f90
(17.9 KiB) Downloaded 322 times
Mickael Hassanaly
Re: Pressure integration on surfaces
Post by Mickael Hassanaly »
The value of iphas is missing here also. Could you post (or send by mail at the support) your mesh and set up?
Mickaël
Marie Pomarède
Hello Mickaël,
Thank you for your answer, and for your suggestion. Unfortunately, even if putting IPHAS = 1 is correct, that does not change our bad results. We continue our investigations (still waiting for calculation results), and in case of no more idea, we will send our files (.xml & mesh).
Many thanks,
Pauline Delteil
Post by Pauline Delteil »
we don't find the right way to go about it. We tested different solutions to calculate the head looses like:
DO ILELT = 1, NLELT
      IFAC = LSTELT(ILELT)
      IEL = IFABOR(IFAC)
      P = P + PROPCE(IEL, IPPROB(IPRTOT(IPHAS))
ENDDO
or
DO ILELT = 1, NLELT
      P = P + PROPCE(IFAC, IPPROB(IPRTOT(IPHAS))
ENDDO
...etc...
but nothing give us good results.
Have you an explain, do we make a mistake somewhere?
We join our .xml and the mesh.
Pauline
dp_coarse_coarse.cgns.gz
(979.75 KiB) Downloaded 335 times
COND_0704_L_W.xml
(5.92 KiB) Downloaded 332 times
Mickael Hassanaly
try to use RTP(IEL,IPR(IPHAS)) and then correct it with P0 term to get the total pressure.
Mickaël Hassanaly
Pauline Delteil
thank you for your answer but in using RTP(IEL,IPR(IPHAS)) corrected with P0(IPHAS), we obtain some results too high.
Maybe it exists an other way to obtain the pressure on the boundary faces.
Pauline
