Error during calculating Process
A. Qohhar
Post by A. Qohhar »
Hi...
This is my first use of code saturne, and i use version 1.3.3. I made a simple geometry, and make a simple calculation. For now, i just want to see a flow pattern from inlet to outlet of my geometry, and i use all parameter uses in case 1 from tutorial file.
But, it alway ended up in error, and i can't find what caused it. Please, anybody can help me. Enclosed i send the mesh and xml file i used.
Thank you for the help, and forgive me for my poor english.
Best regard
Qohhar
new_geom-tar.gz
(1.89 MiB) Downloaded 467 times
Re: Error during calculating Process
Could you also post your error log ?
A. Qohhar
Post by A. Qohhar »
I'm not quite sure what exactly did you meant (it's just because i don't know where to find the error log), but i attach three files from RESU folder.
Hope those three file were the correct one.
Qohhar
08221130.tar.gz
(8.73 KiB) Downloaded 464 times
James McNaughton
Post by James McNaughton »
Hi, it's just a problem with the array size so the calculation won't start.
At the end of your listing file:
 SUBROUTINE CALLING RASIZE             :    MEMTRI
 MEMORY NEEDED    RA (NUMBER OF REALS) =      5210839
        AVAILABLE                      =      5000000
 ----> INCREASE LONGRA IN THE SCRIPT   =       210839 REAL
so you just need to increase LONGRA. If you go look at the lance file in the SCRIPTS folder then you can change it there.
A. Qohhar
Post by A. Qohhar »
Hi...
Thank you James, for the solution. It finally ran. Unfortunately, another error appear, and i'm totally blind 'bout error messages :(
Phase 1 incoming flow detained for 890 outlet faces on 1948
For detailed, listing file attached
At last, is there any refference that can explain kinds of error, and the solution?? since this is my first experience using code_saturne.
Thank you
regards,
Qohhar
listing-08310438.txt
(62.16 KiB) Downloaded 488 times
The calculation seems to start diverging after iteration 5. As you are using the steady algorithm, you may try to modify its parameters, such as the relaxation parameter. The difficulty is probably mesh-related, so you may also try other gradient reconstruction methods than the iterative reconstruction (try least squares with extended neighborhood).
If you still have issues, you may send us your mesh or calculation directory using a large file exchange service.
