How to use Hexahedral mesh ?
Fabien852
Post by Fabien852 »
I wish to use gas combustion module and I have to make volume with hexahedral mesh to do it well.
I don't know why but hexahedral mesh works only with cubes in Salome.
Do you know how use it with a cylinder for example ?
I attached the model that I wish to mesh for use the combustion module.
Fabien
LittleBurner.txt
LittleBurner.hdf
(5.9 MiB) Downloaded 480 times
Re: How to use Hexahedral mesh ?
You may find more help regarding SALOME on the SALOME forum (http://www.salome-platform.org), but to build an "IJK" hexahedral mesh on a cylinder, you will need to subdivide it into several pieced and build an "O-grid" (I don't have an image immediately available, but you can Google for "o-grid" to obtain several pictures).
There is also an experimental block mesh module in SALOME 6.4, but I have never tested it. You may also try the new "body-fitting" algorithm in SALOME.
Fabien852
Post by Fabien852 »
Thank you, I installed the last version of Salome and i tried to use the body-fitting algorithm,
it works pretty well but i don't know how to assign boundary conditions on faces with this algorithm.
You know how ?
Fabien
Martin Isack
Post by Martin Isack »
Hello Fabien,
please have a look in the Salome forum. I asked the same question a view days ago.
http://salome-platform.org/forum/forum_9/206627896
Maritn
Fabien852
Post by Fabien852 »
Thank you, it works but I use the manual way to make boundary faces with "Standalon Group",
Do you succeed to make boundary faces in mesh module from geometry module ?
Fabien
Yes, I often build "groups from geometry". To do this, I usually need to use "new entity -> explode" to build sub elements (i.e. surfaces for a volume) first, and build groups on those.
Fabien852
Post by Fabien852 »
I tried to do this but it doesn't works with Body fitting algorithm.
You have really use it with this algorithm ?
Fabien
