[V8.3 GUI] Unable to change Centering Blend value for Velocity (locked to 1)
Posted: Sun Jan 11, 2026 10:15 am
I am currently using Code_Saturne V8.3 to perform an LES simulation with the WALE model.
I would like to experiment with different numerical schemes for the velocity field. However, I have encountered an issue in the GUI: regardless of which discretization scheme I select (e.g., Blending SOLU/centered), the "Centering Blend" field seems restricted to a value of 1. If I try to input any other value (such as 0.9), the input box turns red and is considered invalid.
Could someone please advise if this is a known limitation in the V8.3 GUI, or if there is a specific setting (like Slope Test) that must be toggled first?
Additionally, I would like to confirm if my understanding of the physics is correct:
If I select "Blending (SOLU/centered)" and set the Centering Blend to 0.9, does this correspond to 90% Central Differencing + 10% Second Order Linear Upwind (SOLU)?
Any clarification or advice would be greatly appreciated.
Xian Ge
Xian Ge
