Error during configue stage of Code Saturne Please help
kellanphil
Post by kellanphil »
Error during configue stage of Code Saturne Please help : : configure:error: cannot find PyQt5 support (>= 5.0) or PyQt4 support (>= 4.5), Graphical User Interface cannot be installed
Re: Error during configue stage of Code Saturne Please help
This question should be in the "installation isssues" section of the forum. Also, do not forget to follow each section's recommendations to save a few question/answer exchanges.
Antech
Post by Antech »
It just means that confugure cannot find PyQt of required versions. Check what versions you have, then search Internet for method installing on your distro. There may be a repository package or you need pip3.
Also, newer Saturne needs C11 C++ or you will catch strange compile errors. So use up-to-date distro or devtoolset with, for example, environment setting for gcc-7 (don't forget to source env-variables right before config/make).
Chai
Post by Chai »
@Antech : in fact , starting with v8.3 it is a c++14 compiler which is required as per the official release notes.
To all: please keep conversations about installation in the installation section of the forum.
