How to Manage Separate Monitoring Outputs with Multiple Probe Files
ximeng
Post by ximeng »
Hi Team,
I'm currently using the cs_user_postprocess_monitors.c file to set up probes and collect their data, as I have a large number of monitors (please see the attached screenshot for reference).
I was wondering if it's possible to use multiple cs_user_postprocess_monitors.c files to generate separate outputs to different Monitoring folders. I tried creating another file named cs_user_postprocess_monitors2.c, and updated the relevant lines to use "Monitoring2" instead of "Monitoring" :
cs_probe_set_t *pset = cs_probe_set_create("Monitoring2");
cs_probe_set_t *pset = cs_probe_set_get("Monitoring2");
However, it doesn’t seem to work at compiling stage. Is there a recommended way to achieve this separation of outputs using multiple monitoring files?
Thanks in advance for your support!
(4.04 KiB) Downloaded 1146 times
Re: How to Manage Separate Monitoring Outputs with Multiple Probe Files
You cannot define the same function in multiple files, but you can define multiple probe sets in a single cs_user_postprocess_probes function.
If you have many similar probe sets, I recommend declaring them in a loop rather than copy/pasting the same instructions.
ximeng
Post by ximeng »
Thanks.
I can use a single cs_user_postprocess_probes function, but the issue is that I want the outputs to be separate files. Since the number of probes is very large, combining all the data into one file results in a huge output, making postprocessing difficult and inefficient.
To use different directories, you need to create one writer per directory, using cs_post_define_writer (where you can define a separate directory for each writer) , then use "cs_probe_set_associate_writers" to assign a different writer for each probe set.
In any case, if you really have a huge amount of probes, computing/interpolating values and outputting the results may not be very efficient. In this case, outputting volumic data or doing at least some partial filtering with in-situ postprocessing (possibly using Catalyst) may be a good choice.
