MPI-OpenMP hybrid support
Posted: Thu May 08, 2025 7:00 pm
I am currently trying to run Code_Saturne in conjunction with another code on my HPC system using MPI and OpenMP, but when I try to use more than one node, the computation fails since it seems to try to generate one results folder per node. I have already managed to use Code_Saturne with multiple cores on one node on my HPC (though on a different cluster), so I would just like to check if Code_Saturne supports MPI and OpenMP hybrid jobs.
I have attached the run_solver.log file. I couldn't upload the PBS error and output files and my job submission script so there are here below.
Thanks!
Error file:
Output file:
Job script:
Thanks!
Error file:
The following have been reloaded with a version change:
1) GCCcore/13.2.0 => GCCcore/11.2.0
2) bzip2/1.0.8-GCCcore-13.2.0 => bzip2/1.0.8-GCCcore-11.2.0
3) ncurses/6.4-GCCcore-13.2.0 => ncurses/6.2-GCCcore-11.2.0
4) zlib/1.2.13-GCCcore-13.2.0 => zlib/1.2.11-GCCcore-11.2.0
1) GCCcore/11.2.0 => GCCcore/13.3.0
2) binutils/2.40-GCCcore-13.2.0 => binutils/2.42-GCCcore-13.3.0
3) zlib/1.2.11-GCCcore-11.2.0 => zlib/1.3.1-GCCcore-13.3.0
1) GCCcore/13.3.0 => GCCcore/11.3.0
2) UCX/1.16.0-GCCcore-13.3.0 => UCX/1.12.1-GCCcore-11.3.0
3) binutils/2.42-GCCcore-13.3.0 => binutils/2.38-GCCcore-11.3.0
4) iimpi/2024a => iimpi/2022a
5) impi/2021.13.0-intel-compilers-2024.2.0 => impi/2021.6.0-intel-compilers-2022.1.0
6) intel-compilers/2024.2.0 => intel-compilers/2022.1.0
7) numactl/2.0.18-GCCcore-13.3.0 => numactl/2.0.14-GCCcore-11.3.0
8) zlib/1.3.1-GCCcore-13.3.0 => zlib/1.2.12-GCCcore-11.3.0
1) GCCcore/13.2.0 => GCCcore/13.3.0
2) zlib/1.2.13-GCCcore-13.2.0 => zlib/1.3.1-GCCcore-13.3.0
1) GCCcore/13.3.0 => GCCcore/13.2.0
2) binutils/2.42-GCCcore-13.3.0 => binutils/2.40-GCCcore-13.2.0
3) zlib/1.3.1-GCCcore-13.3.0 => zlib/1.2.13-GCCcore-13.2.0
1) numactl/2.0.18-GCCcore-13.3.0 => numactl/2.0.16-GCCcore-13.2.0
1) UCX/1.16.0-GCCcore-13.3.0 => UCX/1.15.0-GCCcore-13.2.0
3) zlib/1.2.13-GCCcore-13.2.0 => zlib/1.3.1-GCCcore-13.3.0
1) zlib/1.3.1-GCCcore-13.3.0 => zlib/1.2.13-GCCcore-13.2.0
File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/bin/code_saturne", line 89, in <module>
retcode = cs.execute()
File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/lib/python3.11/site-packages/code_saturne/cs_script.py", line 96, in execute
File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/lib/python3.11/site-packages/code_saturne/cs_script.py", line 181, in run
File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/lib/python3.11/site-packages/code_saturne/cs_run.py", line 690, in main
return run(argv, pkg)[0]
File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/lib/python3.11/site-packages/code_saturne/cs_run.py", line 661, in run
retval = c.run(n_procs=r_c['n_procs'],
File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/lib/python3.11/site-packages/code_saturne/cs_case.py", line 1845, in run
self.set_result_dir(force_id)
File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/lib/python3.11/site-packages/code_saturne/cs_case.py", line 634, in set_result_dir
os.mkdir(self.result_dir)
FileExistsError: [Errno 17] File exists: '/gpfs/home/bt1022/hx1_subchcfd/SubChCFD/coarse/RESU/iteration_1'
Warning:
Will try to use 12 processes while resource manager (PBS)
allows for 32.
[hx1-c08-8-1:735848] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735847] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735844] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735853] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735852] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735854] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735849] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735845] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735851] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735843] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735847] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735844] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735853] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735848] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735852] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735846] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735849] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735854] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735850] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735845] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735851] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735843] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735846] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735850] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
Error in calculation stage.
code_saturne
Version: 7.0.6
Path: /gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64
Result directory:
Copying base setup data
Compiling and linking user-defined functions
Preparing calculation data
Parallel code_saturne on 12 processes.
Preprocessing calculation
Starting calculation
initializing
Post-calculation operations
CPU Time used: 00:00:32
CPU Percent: 88%
Memory usage: 5589608kb
Approx Power usage: 0.0
Walltime usage: 00:00:40
#!/bin/sh
#PBS -koed
#PBS -lselect=2:ncpus=16:mpiprocs=16:mem=100gb
#PBS -lwalltime=25:00:00
## MODULES TO LOAD @ RUNTIME:
module load tools
module load Python
module load libgd
module load intel
module load SCOTCH
## RUN COMMAND
cd /gpfs/home/bt1022/hx1_subchcfd
mpirun -n 2 /gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/bin/code_saturne run --case /gpfs/home/bt1022/hx1_subchcfd/SubChCFD/coarse -n 12
