MPI-OpenMP hybrid support
saintlyknighted
Post by saintlyknighted »
I am currently trying to run Code_Saturne in conjunction with another code on my HPC system using MPI and OpenMP, but when I try to use more than one node, the computation fails since it seems to try to generate one results folder per node. I have already managed to use Code_Saturne with multiple cores on one node on my HPC (though on a different cluster), so I would just like to check if Code_Saturne supports MPI and OpenMP hybrid jobs.
I have attached the run_solver.log file. I couldn't upload the PBS error and output files and my job submission script so there are here below.
Thanks!
Error file:
The following have been reloaded with a version change:
  1) GCCcore/13.2.0 => GCCcore/11.2.0
  2) bzip2/1.0.8-GCCcore-13.2.0 => bzip2/1.0.8-GCCcore-11.2.0
  3) ncurses/6.4-GCCcore-13.2.0 => ncurses/6.2-GCCcore-11.2.0
  4) zlib/1.2.13-GCCcore-13.2.0 => zlib/1.2.11-GCCcore-11.2.0
  1) GCCcore/11.2.0 => GCCcore/13.3.0
  2) binutils/2.40-GCCcore-13.2.0 => binutils/2.42-GCCcore-13.3.0
  3) zlib/1.2.11-GCCcore-11.2.0 => zlib/1.3.1-GCCcore-13.3.0
  1) GCCcore/13.3.0 => GCCcore/11.3.0
  2) UCX/1.16.0-GCCcore-13.3.0 => UCX/1.12.1-GCCcore-11.3.0
  3) binutils/2.42-GCCcore-13.3.0 => binutils/2.38-GCCcore-11.3.0
  4) iimpi/2024a => iimpi/2022a
  5) impi/2021.13.0-intel-compilers-2024.2.0 => impi/2021.6.0-intel-compilers-2022.1.0
  6) intel-compilers/2024.2.0 => intel-compilers/2022.1.0
  7) numactl/2.0.18-GCCcore-13.3.0 => numactl/2.0.14-GCCcore-11.3.0
  8) zlib/1.3.1-GCCcore-13.3.0 => zlib/1.2.12-GCCcore-11.3.0
  1) GCCcore/13.2.0 => GCCcore/13.3.0
  2) zlib/1.2.13-GCCcore-13.2.0 => zlib/1.3.1-GCCcore-13.3.0
  1) GCCcore/13.3.0 => GCCcore/13.2.0
  2) binutils/2.42-GCCcore-13.3.0 => binutils/2.40-GCCcore-13.2.0
  3) zlib/1.3.1-GCCcore-13.3.0 => zlib/1.2.13-GCCcore-13.2.0
  1) numactl/2.0.18-GCCcore-13.3.0 => numactl/2.0.16-GCCcore-13.2.0
  1) UCX/1.16.0-GCCcore-13.3.0 => UCX/1.15.0-GCCcore-13.2.0
  3) zlib/1.2.13-GCCcore-13.2.0 => zlib/1.3.1-GCCcore-13.3.0
  1) zlib/1.3.1-GCCcore-13.3.0 => zlib/1.2.13-GCCcore-13.2.0
  File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/bin/code_saturne", line 89, in <module>
    retcode = cs.execute()
  File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/lib/python3.11/site-packages/code_saturne/cs_script.py", line 96, in execute
  File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/lib/python3.11/site-packages/code_saturne/cs_script.py", line 181, in run
  File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/lib/python3.11/site-packages/code_saturne/cs_run.py", line 690, in main
    return run(argv, pkg)[0]
  File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/lib/python3.11/site-packages/code_saturne/cs_run.py", line 661, in run
    retval = c.run(n_procs=r_c['n_procs'],
  File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/lib/python3.11/site-packages/code_saturne/cs_case.py", line 1845, in run
    self.set_result_dir(force_id)
  File "/gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/lib/python3.11/site-packages/code_saturne/cs_case.py", line 634, in set_result_dir
    os.mkdir(self.result_dir)
FileExistsError: [Errno 17] File exists: '/gpfs/home/bt1022/hx1_subchcfd/SubChCFD/coarse/RESU/iteration_1'
Warning:
  Will try to use 12 processes while resource manager (PBS)
   allows for 32.
[hx1-c08-8-1:735848] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735847] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735844] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735853] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735852] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735854] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735849] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735845] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735851] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735843] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735847] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735844] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735853] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735848] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735852] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735846] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735849] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735854] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735850] mca_base_component_repository_open: unable to open mca_btl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735845] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735851] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735843] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735846] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
[hx1-c08-8-1:735850] mca_base_component_repository_open: unable to open mca_mtl_ofi: libefa.so.1: cannot open shared object file: No such file or directory (ignored)
 Error in calculation stage.
Output file:
                      code_saturne
Version:   7.0.6
Path:      /gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64
Result directory:
Copying base setup data
Compiling and linking user-defined functions
Preparing calculation data
 Parallel code_saturne on 12 processes.
Preprocessing calculation
Starting calculation
initializing
Post-calculation operations
CPU Time used: 00:00:32
CPU Percent: 88%
Memory usage: 5589608kb
Approx Power usage: 0.0
Walltime usage: 00:00:40
Job script:
#!/bin/sh
#PBS -koed
#PBS -lselect=2:ncpus=16:mpiprocs=16:mem=100gb
#PBS -lwalltime=25:00:00
## MODULES TO LOAD @ RUNTIME:
module load tools
module load Python
module load libgd
module load intel
module load SCOTCH
## RUN COMMAND
cd /gpfs/home/bt1022/hx1_subchcfd
mpirun -n 2 /gpfs/home/bt1022/code_saturne/install_path/Code_Saturne/7.0.6/code_saturne-7.0.6/arch/Linux_x86_64/bin/code_saturne run --case /gpfs/home/bt1022/hx1_subchcfd/SubChCFD/coarse -n 12
run_solver.log
(10.25 KiB) Downloaded 5527 times
Re: MPI-OpenMP hybrid support
Yes, the code should work fine in hybrid MPI/OPenMP mode, and even though in most cases performance is slightly better in pure MPI mode, hybrid mode often requires a bit less memory so can be useful, and may be improved in the future (current work on GPU performance should also improve OpenMP performance). We have at least one nightly test which runs in hybrid mode.
If you have the issue only with more than one node, it is probably related to MPI parameters. Is the MPI library used/tested on multiple nodes on the same cluster ?
Also, in your logs, the crash seems related to PT-Scotch, not to run directories (at least in the provided logs). PT-Scotch can be pretty fragile when using threading, so I suggest using a more up to date PT-Scotch version, and possibly disabling threading. In our recent builds, we had performance issues with PT-Scotch threading, so needed to use build parameters to limit threading or at least thread placement (using the -DCOMMON_PTHREAD_AFFINITY_LINUX flag, as described in the Scotch install documentation).
You can also use code_saturne's built-in space-filling curve (Morton or Hilbert) partitioning, at least for initial tests, and to make sure issues are not solely related to external libraries.
saintlyknighted
Thanks Yvan.
Good to know that hybrid mode works. I have tried a few things but nothing works so far, I will probably ask my HPC staff for help. There is also a chance I might not actually need to run my simulations in hybrid mode after all so I will see how things pan out.
Bryan
Did you try running the code in pure MPI mode over 2 nodes ? Do you have the same issues ?
