head losses coefficient - consistent definition
daniele
Post by daniele »
I am wondering about the interpretation of the head loss coefficient in code_Saturne.
The "Head losses" panel in the GUI says:
"Head losses coefficients: ... = -0.5*rho*alpha_ij*|U|*U_j"
Which would indicate that only the "alpha" term must be specified by the user.
However, looking in the sources, I could find the multiplication by rho (line 1177 of cs_solve_navier_stokes.cpp), but not the "0.5" multiplication.
Could you help me in understanding the correct formulation adopted by the solver, once I specify a coefficient through the cs_head_losses.c routine?
Thank you very much in advance for your help.
Daniele
Re: head losses coefficient - consistent definition
Yes, when you use the GUI, you only need to specify the "alpha" term, which is multipled by 0.5*|U| in the cs_gui_head_losses function, to build the ckupdc term which is itself multiplied by rho*U in the function and line you mention.
When using the cs_user_head_losses term, the user directly specifies the ckupdc term, so must include 0.5*|U| in the expression. I know this logic has been in place since the early days of the code, but do not know the rationale of why this is so for the user-defined function (though when using a more complex law, where alpha is not constant, and the final expression is a polynomial with terms in U in addition to terms in U.U, this can avoid some divisions by U so be better from a numerical standpoint).
daniele
Post by daniele »
Hello Yvan.
Thank you for your precious and accurate help, as usual.
That answers perfectly my question.
Daniele
