Page 1 of 3
Library not found with custom compile file
Posted: Wed Sep 18, 2024 10:44 am
by fracenvi
I'm trying to run a case where i have implemented a Pytorch-based neural network in the cs_user_extra_operations.c file and i need to link the libraries needed for having the full implementation (i.e., Libtorch). I made a custom cs_user_scripts.py where in the domain.compile_libs variables i correctly introduced the path to the libraries i need to include (i also checked with a separate file that those are the one needed for compiling the file that is missing the library). Do you know what else can be the problem in this regards?
The variable in question:
domain.compile_libs = '-lstdc++ -Wall -O3 -g -I/path/to/libtorch/include -I/path/to/libtorch/include/torch/csrc/api/include -L/path/to/libtorch/lib -ltorch -ltorch_cpu -lc10 -lstdc++'
Re: Library not found with custom compile file
Posted: Thu Sep 19, 2024 12:43 am
I recommend separating compile and link flags:
domain.compile_cflags = "-I/path/to/libtorch/include -I/path/to/libtorch/include/torch/csrc/api/include"
domain.compile_cxxflags = "-I/path/to/libtorch/include -I/path/to/libtorch/include/torch/csrc/api/include"
domain.compile_fcflags = None
domain.compile_libs = "-L/path/to/libtorch/lib -ltorch -ltorch_cpu -lc10 -lstdc++"
If this still doesn't work, can you post the compile.log file in the RESU/<run_id> directory.
Of course, do not forget to replace/check the actual /path/to/libtorch and replace it with the real value.
Posted: Thu Sep 19, 2024 10:58 am
by fracenvi
Thank you very much Yvan, it worked perfectly. However, now i have another issue: it seems to perfectly compile everything as in the compile.log file there are no errors (only warnings on unused variables), yet the calculation doesn't even start with the first iteration and it gives me no error message whatsoever. I attached the files that are produced by the code at the end of the computation.
Do you have any idea of what can possibly cause this behavior?
Francesco
Posted: Thu Sep 19, 2024 6:21 pm
Do you get any info in the terminal in which the computation is launched (if interactive) or in the batch log files ?
Is the cs_solver file created ?
Posted: Fri Sep 20, 2024 2:10 pm
by fracenvi
In my terminal i have no relevant information.
In the only log that i have (compile.log), everything seems to be linked in the right way. In the following is the last line of the terminal:
/usr/bin/cc -o /home/cenvinzf@coria.fr/workdir/full_coupling/case1/RESU/20240920-1202/cs_solver cs_user_extra_operations.o cs_meg_initialization.o cs_meg_boundary_function.o cs_user_initialization.o cs_user_parameters-base.o predict.o cs_f_user_physical_properties.o cs_user_parameter.o -lcs_solver -L/home/cenvinzf@coria.fr/libtorch/lib -lc10 -ltorch -ltorch_cpu -lstdc++ -L/home/cenvinzf@coria.fr/CS_ANN_coupling/7.0.0/lib -L/home/cenvinzf@coria.fr/Desktop/saturne_lib/cgns/inst/lib -L/home/cenvinzf@coria.fr/Desktop/med/lib -L/home/cenvinzf@coria.fr/Desktop/hdf5-200/inst/lib -L/home/cenvinzf@coria.fr/Desktop/OpenMPI/lib -O -Wl,-export-dynamic -fopenmp -lsaturne -lple -lcgns -lmedC -lhdf5 -lmpi -lz -ldl -L/home/cenvinzf@coria.fr/opencv_folder/lib -L/home/cenvinzf@coria.fr/cppflow/lib -L/usr/lib/gcc/x86_64-linux-gnu/11 -L/usr/lib/x86_64-linux-gnu -L/usr/lib -L/lib/x86_64-linux-gnu -L/lib -L. -L/home/cenvinzf@coria.fr/opencv_folder/include -L/home/cenvinzf@coria.fr/cppflow/include -lgfortran -lquadmath -lm -Wl,-rpath -Wl,:/home/cenvinzf@coria.fr/libtorch/lib:/home/cenvinzf@coria.fr/CS_ANN_coupling/7.0.0/lib:/home/cenvinzf@coria.fr/Desktop/saturne_lib/cgns/inst/lib:/home/cenvinzf@coria.fr/Desktop/med/lib:/home/cenvinzf@coria.fr/Desktop/hdf5-200/inst/lib:/home/cenvinzf@coria.fr/Desktop/OpenMPI/lib:/home/cenvinzf@coria.fr/Desktop/OpenMPI/lib/../lib:/home/cenvinzf@coria.fr/opencv_folder/lib/../lib:/home/cenvinzf@coria.fr/opencv_folder/include/../lib:/home/cenvinzf@coria.fr/cppflow/lib/../lib:/home/cenvinzf@coria.fr/cppflow/include/../lib:/home/cenvinzf@coria.fr/Desktop/OpenMPI/lib:.:/home/cenvinzf@coria.fr/opencv_folder/lib:/home/cenvinzf@coria.fr/opencv_folder/include:/home/cenvinzf@coria.fr/cppflow/lib:/home/cenvinzf@coria.fr/cppflow/include
When i try to compile first (using code_saturne compile) the cs_solver executable is produced but gives me the error:
./cs_solver: error while loading shared libraries: libhdf5.so.200: cannot open shared object file: No such file or directory
even if the HDF5 library is correctly linked from the moment the code is installed.
Any suggestion?
Francesco
Posted: Fri Sep 20, 2024 10:08 pm
Does the hdf5 file version match the one in the build configure command for code_saturne ? Do you have the same environment settings or loaded modules when installing and trying to run the code ?
Looks like there may beca mismatch here.
Posted: Mon Sep 23, 2024 11:01 am
by fracenvi
I tried to install once again the code using the same libraries and configuration options to make sure that the hdf5 versions (between configure and compile) match, as well as re-running my case but once again it gives me the "not found library" error.
Here it is the command line i used to run the compile step:
cs_ann_2 compile --cflags='-L/home/cenvinzf@coria.fr/libtorch/lib -lc10 -ltorch -ltorch_cpu' --cxxflags='-I/home/cenvinzf@coria.fr/libtorch/include -I/home/cenvinzf@coria.fr/libtorch/include/torch/csrc/api/include' --libs='-L/home/cenvinzf@coria.fr/libtorch/lib -lc10 -ltorch -ltorch_cpu -L/home/cenvinzf@coria.fr/Desktop/hdf5-200/inst2/lib -lhdf5 -lstdc++'
Whereas this one is part of the options used in configuration phase:
--with-hdf5=/home/cenvinzf@coria.fr/Desktop/hdf5-200/inst2 --with-hdf5-include=/home/cenvinzf@coria.fr/Desktop/hdf5-200/inst2/include -with-hdf5-lib=/home/cenvinzf@coria.fr/Desktop/hdf5-200/inst2/lib
I don't get where the missmatch can happen. I also posted the files needed to reproduce the bug.
Thanks and regards,
Francesco
Posted: Wed Oct 02, 2024 1:08 am
Could you replace:
With:
-L/home/cenvinzf@coria.fr/Desktop/hdf5-200/inst2/lib -Wl,-rpath -Wl,/home/cenvinzf@coria.fr/Desktop/hdf5-200/inst2/lib
Or add
export LD_LIBRARY_PATH=/home/cenvinzf@coria.fr/Desktop/hdf5-200/inst2/lib
In your launch environment (in you batch header, or in a [compute_prologue] section in your run.cfg file) ?
The "-L" option helps find the library at link time but not at execution time.
Posted: Wed Oct 02, 2024 6:32 pm
by fracenvi
I did manage to sort the issue related to the libhdf5.so.200 file missing, but now it seems to be giving another issue:
./cs_solver: error while loading shared libraries: libple.so.2: cannot open shared object file: No such file or directory
But i checked and it seems to be present in the relative lib folder.
I found a previous post talking about that same issue (viewtopic.php?t=3052&start=20), but i can't manage to find a solution. I have already tried to move to v8.0.3.
Any suggestions?
Francesco
Posted: Thu Oct 03, 2024 12:23 am
Could you post the run_solver file in your execution directory ? Also, odes the code run normally without the additional libary ?
For PLE, you could also solve the issue in a manner similar to hdf5, but It would be interesting to first understand why you have this issue.
