CS/Syrthes in Ubuntu 20 vs Ubuntu 22
aminer2k
Post by aminer2k »
I have CS 8.0 and Syrthes 5.0 running coupling problems in Ubuntu 22, without issue.
I need to set up a second system, which is Ubuntu 20. After reinstalling a couple of times, following the steps that worked on my Ubuntu 22 system, I still get an error.
CS gui runs fine.
Syrthes gui runs fine.
When launching a coupled case that runs fine on Ubuntu 22, now launching in my Ubuntu 20 setup, I get the following error:
Set syrthes_home based on SYRTHES4_HOME: /home/a/syrthes5.0/arch/Linux_x86_64
  File "/home/a/code_saturne/8.0.3/code_saturne-8.0.3/arch/Linux_x86_64/lib/python3.8/site-packages/code_saturne/base/cs_case_coupling.py", line 170, in coupling
    dom = syrthes_domain(package,
  File "/home/a/code_saturne/8.0.3/code_saturne-8.0.3/arch/Linux_x86_64/lib/python3.8/site-packages/code_saturne/base/cs_case_domain.py", line 1532, in __init__
    source_syrthes_env(self.package, verbose, force=True)
  File "/home/a/code_saturne/8.0.3/code_saturne-8.0.3/arch/Linux_x86_64/lib/python3.8/site-packages/code_saturne/base/cs_exec_environment.py", line 1004, in source_syrthes_env
    syr_profile = os.path.join(config.get('install', 'syrthes'),
  File "/usr/lib/python3.8/configparser.py", line 781, in get
    d = self._unify_values(section, vars)
  File "/usr/lib/python3.8/configparser.py", line 1149, in _unify_values
    raise NoSectionError(section) from None
configparser.NoSectionError: No section: 'install'
I pointed Syrthes to the CS libpe directory, in the setup file, I think.
The setup files I used are attached. (this site does not allow the CS setup file to be uploaded. pasted below.)
Any idea what this error is?
Any indication what this is?
setup file modifications at the end:
# Name Use Install Path
hdf5 yes yes None
cgns yes yes None
med yes yes None
scotch yes yes None
parmetis no no None
setup.ini
(4.33 KiB) Downloaded 6651 times
Re: CS/Syrthes in Ubuntu 20 vs Ubuntu 22
Did you do the post-install part of the code_saturne setup (i.e. editing the code_saturne.cfg file in the installation directory) ? Looks like this is missing, based on your error message.
