Convergence issues with CGNS mesh from Star-CCM+
Posted: Fri May 10, 2024 4:25 pm
Hi everyone,
I am running into convergence issues with my Code_Saturne simulations where I use a CGNS mesh generated by Star-CCM+. As shown in the screenshot attached, the residuals tend to stabilise around a rather significant value (10^1 in this case, but 10^-1 in others), before eventually diverging after a couple hundred iterations. The test case where these residuals are from can be found here: https://www.dropbox.com/scl/fi/faj6qcwv ... 85le4&dl=0.
This test case simply consists of a short pipe flow without any thermal model activated, but even this simple case diverges, as with every other simulation using a Star-CCM+ mesh, though the mesh works fine when using Star-CCM+ itself (as would be expected). This leads me to believe there is something wrong either with the way I export the mesh to use in Code_Saturne, or the way Code_Saturne interacts with the mesh.
For reference, I've had to change the library version number of the CGNS meshes from Star-CCM+ from 3.4 to 3.3 using cgnsview (as described here: viewtopic.php?p=17194#p17194), before they can be used by Code_Saturne.
