CGNS: error checking file type
mmagain
Post by mmagain »
I am following the "full domain" tutorial. More specifically, the first case. When I arrive at the computation stage. I get the following error displayed :
                      code_saturne
Version:   7.0.6-patch
Path:      /home/fuxin/Code_Saturne/7.0.6-patch/code_saturne-7.0.6-patch/arch/Linux_x86_64
Result directory:
  /home/fuxin/Desktop/Code_Saturne_Tutorials/full_domain/case1/RESU/20240412-0235
Copying base setup data
Compiling and linking user-defined functions
Preparing calculation data
 Single processor code_saturne simulation.
Preprocessing calculation
Post-calculation operations
Error running the preprocessor.
Check the preprocessor.log file for details.
Error in preprocessing stage.
Inspecting the logs, I see this :
/home/fuxin/Code_Saturne/7.0.6-patch/code_saturne-7.0.6-patch/arch/Linux_x86_64/libexec/code_saturne/cs_preprocess
--out mesh_input/mesh_03.csm --log preprocessor_03.log --case preprocessor_03
/home/fuxin/Desktop/Code_Saturne_Tutorials/full_domain/MESH/vessel.cgns
  |   Code_Saturne Preprocessor  |
  code_saturne version 7.0.6-patch   (built Thu Jan 11 18:43:35 2024)
  CGNS 4.1.0 file format support
  MED 4.1.1 (HDF5 1.10.6) file format support
  Reading of compressed files ('.gz') with Zlib 1.2.11
Case configuration
  Date                : Fri Apr 12 02:35:31 2024
  System              : Linux 5.15.0-102-generic
  Machine             : fuxin
  Processor           : AMD Ryzen 7 5800X 8-Core Processor
  Memory              : 16275496
  User                : fuxin (fuxin)
  Directory           : /home/fuxin/Desktop/Code_Saturne_Tutorials/full_domain/case1/RESU/20240412-0235
  Case name           : preprocessor_03
  Mesh file           : /home/fuxin/Desktop/Code_Saturne_Tutorials/full_domain/MESH/vessel.cgns
Reading mesh from file in CGNS format
  Mesh file: /home/fuxin/Desktop/Code_Saturne_Tutorials/full_domain/MESH/vessel.cgns
/home/fuxin/Documents/saturne-src/code_saturne/preprocessor/pre-post/ecs_pre_cgns.c:250: Fatal error.
CGNS: error checking file type "/home/fuxin/Desktop/Code_Saturne_Tutorials/full_domain/MESH/vessel.cgns":
no CGNS error reported
Call stack
   1: 0x563e1a52017f <ecs_pre_cgns__lit_maillage+0x41af> (cs_preprocess)
   2: 0x563e1a5175b3 <ecs_pre__lit_maillage+0x103>    (cs_preprocess)
   3: 0x563e1a50f390 <main+0xa0>                      (cs_preprocess)
   4: 0x7fdb647b3083 <__libc_start_main+0xf3>         (libc.so.6)
   5: 0x563e1a50fbde <_start+0x2e>                    (cs_preprocess)
Any idea on how to solve this problem? I haven't seen anything related to this issue on this forum. The other two meshes in .med file type are preprocessing correctly. Only vessel.cgns seems to cause the issue.
If it can be of any information, I did the simple junction tutorial without any problems.
Thank you in advance,
Michael
Re: CGNS: error checking file type
This error means a CGNS library call (cg_is_cgns) checking that the file is indeed a CGNS file has failed.
This could be a bug in the CGNS library (we have tested 4.1.2, 4.4.0, and some 4.3 versions I think, but I am not sure about 4.1.0), and install issue (if CGNS is not built with HDF5 support), or a corrupted file.
If you have the CGNS tools installed, can you open the file using cgnsview or cgnscheck) ? That would help guide further checks.
