salome to code_saturne
Posted: Wed Apr 10, 2024 2:54 pm
by hiba
I am very new to code_saturne, I am not sure id this question is related to salome or to code_saturne, when I create my geometry (domain with a cylinder), I run the mesh preprocessing only, and I get the following error:
Error in preprocessing stage.
Run failed in preprocessing stage.
I hope you can help me solve this problem, thank you!
I've attached the preprocessor file.
Re: salome to code_saturne
Posted: Thu Apr 11, 2024 2:06 am
This should be in the code_saturne usage section, so I may move this topic to that section soon.
The preprocessor log you posted explains the problem: you have only meshed the cylinder's surface, not its volume. So you need to fix your mesh.
