Hello everyone,
I am very new to code_saturne, I am not sure id this question is related to salome or to code_saturne, when I create my geometry (domain with a cylinder), I run the mesh preprocessing only, and I get the following error:
Error running the preprocessor.
Check the preprocessor.log file for details.
Error in preprocessing stage.
Run failed in preprocessing stage.
I hope you can help me solve this problem, thank you!
I've attached the preprocessor file.
salome to code_saturne
- preprocessor.log
- (3.14 KiB) Downloaded 10811 times
Re: salome to code_saturne
This should be in the code_saturne usage section, so I may move this topic to that section soon.
The preprocessor log you posted explains the problem: you have only meshed the cylinder's surface, not its volume. So you need to fix your mesh.
