I am using Code_saturne version 7.1.2. and trying to solve 2D convergent nozzle. I met with the following error.
Symmetric Gauss-Seidel: error (divergence) solving for TempK
1: 0x14e241e721da <cs_sles_it_error_post_and_abort+0x8a> (libsaturne-7.1.so)
2: 0x14e241e67322 <cs_sles_solve+0x2d2> (libsaturne-7.1.so)
3: 0x14e241e683ab <cs_sles_solve_native+0x3db> (libsaturne-7.1.so)
4: 0x14e241a615d5 <cs_equation_iterative_solve_scalar+0xc15> (libsaturne-7.1.so)
5: 0x14e241a1e943 <covofi_+0x4d11> (libsaturne-7.1.so)
6: 0x14e241b6db72 <scalai_+0x8ff> (libsaturne-7.1.so)
7: 0x14e241b78c95 <tridim_+0x4581> (libsaturne-7.1.so)
8: 0x14e2419e7ff1 <caltri_+0x1c8b> (libsaturne-7.1.so)
9: 0x14e242af1ec3 <main+0x6f3> (libcs_solver-7.1.so)
10: 0x14e2404084a3 <__libc_start_main+0xf3> (libc.so.6)
11: 0x40194e <_start+0x2e> (cs_solver)
It occurred when I use pressure gradient in source_terms.c user subroutine.
I also tried to run it on 7.3.0 version and it gave me the same error.
I have attached the subroutine and log file.
Thanks.
Kind regards,
Hyder.
- cs_user_source_terms-base.c
- (6.32 KiB) Downloaded 1289 times
- run_solver.log
- (23.91 KiB) Downloaded 1319 times
Re: Symmetric Gauss-Seidel: error (divergence) solving for TempK
Using only explicit source terms can lead to instability.
It might be interesting to test by removing only the ST on enthalpy (since that is the variable which diverges first), and if that removes the isse, restore it but multiplying by a factor < 1... Then see up to which factor (i.e. source term strength the computation is OK). If that is the issue, using a ramp in time to add the source term gradually or smaller time steps (at start) might work.
I used the ideal gas equation to define pressure gradient in terms of density and temperature to get an implicit source term, this solved the problem.
Thanks.
Best,
Hyder.
Thanks.
Best,
Hyder.
