Call the rotational axis and rotational velocity in user_subrutine in C
hyder4
Post by hyder4 »
Dear Developers,
I am using frozen rotor model and I want to call the rotation axis and velocity from GUI to my user subrutine in C.
what function should I use? Thanks!
Kind regards,
Hyder.
Re: Call the rotational axis and rotational velocity in user_subrutine in C
Check the Doxygen documentation for cs_rotation.c.
When running a turbomachinery case, rotation 0 matches the stator, and each subsequent rotation id matches the rotors, in order of declaration, so if you defined a single rotor in the GUI, simply access it as rotation 1 with the functions from cs_rotation.c/h.
hyder4
Post by hyder4 »
Got it, thank you.
May I also ask how can I call rotation velocity and axis if I am using Coriolis source term option in body force in GUI?
Best,
Hyder.
If you are using the Coriolis source term, the whole domain is in rotation, which matches rotation id 0 (in C).
The logic is then the same as for turbomachinery.
Note that I do not know if Coriolis + turbomachinery are compatible, as we do not consider compostion of rotations. I believe that would be possible with "not too complicated" adjustments, but the combination would probably provide incorrect results today.
hyder4
Post by hyder4 »
Got it, thanks.
Best,
Hyder.
