Error running long pipe with variable density subroutine
hyder4
Post by hyder4 »
I was running a simulation of a long pipe to check user subroutine in which I defined density as variable using the ideal gas equation and I got an error as follows.
code_saturne_7.1_git/code_saturne-7.1/src/base/cs_field.c:1103: Fatal error.
Fortran pointer of rank 1 requested for values of field "velocity",
which have rank 2.
I have attached the subroutines, setup and mesh.
Kind regards,
Hyder.
ICM.cgns
(4.88 MiB) Downloaded 421 times
cs_user_physical_properties.f90
(5.75 KiB) Downloaded 451 times
cs_user_parameters.c
(3.34 KiB) Downloaded 445 times
hyder4
Re: Error running long pipe with variable density subroutine
Post by hyder4 »
Setup file.
setup.xml
(7.77 KiB) Downloaded 453 times
do you have a stack trace so as to know from which functions this was called ? If it is in the user-defined properties, it means some other index might be wrong, since velocity is not mentioned explicitly...
Also, version 7.1 is retired, so I recommend using version 8.0-beta instead, which is being fully tested, and update (bug fixes only) to v8.0 when it is released next June.
hyder4
Post by hyder4 »
do you mean this?
all stack:
1: 0x7fc413989bfe <cs_f_field_var_ptr_by_id+0x7e> (libsaturne-7.1.so)
2: 0x7fc4140c2c6c <__field_MOD_field_get_val_s+0x21> (libsaturne-7.1.so)
3: 0x556e5065037d <usphyv_+0x74> (cs_solver)
4: 0x7fc413a7cd9b <phyvar_+0x1c2> (libsaturne-7.1.so)
5: 0x7fc4139059fa <caltri_+0x5bc> (libsaturne-7.1.so)
6: 0x7fc4147f2b81 <main+0x721> (libcs_solver-7.1.so)
7: 0x7fc41365d0b3 <__libc_start_main+0xf3> (libc.so.6)
8: 0x556e5065008e <_start+0x2e> (cs_solver)
Hyder.
Yes.
This confirms the error occurs in the usphyv code.
Answering from my phone so I can't check in detail right now. Running a debug build could be interesting.
hyder4
Post by hyder4 »
Thank you. Please keep me updated.
best,
Hyder.
Your usphyv definition is incorrect.
For some reason, you have commented the "dt" part out of the subroutine definition. Since the function is a standard function of the code, you must never do that unless you reinstall the code with the same modification in the reference file and call site. This can be a source of the bug.
So first fix this, than test again.
You might also try moving the "irovar" setting from cs_user_parameters to cs_user_model (called earlier) in the same file.
Also, you need to remove the "#pragma weak" line.
If this is not sufficient, comment the calls to field_get_val_s one by one to see which one is responsible, but in this case I would suspect an install issue...
hyder4
Post by hyder4 »
I have done everything you described and also installed sauterne version 7.3.0. it seems the error is coming when I call the temperature using { call field_get_val_s(ivarfl(isca(iscalt)),cvar_scalt)} function in the subroutine.
is there a way to solve this problem?
one of the interesting thing is the same subroutine is working well in closed cavity geometry ( no inlet and outlet)
I have attached the improved subroutines.
Hyder.
(5.75 KiB) Downloaded 439 times
(3.29 KiB) Downloaded 427 times
Are you sure the thermal model is activated in rhis case ? If not, that could explain the issue.
hyder4
Post by hyder4 »
Thanks it solved the problem.
Best,
Hyder.
