hi,
in the cpincl.f90 of 2.1.4 ncs, it reads,
! - Proprietes
! ICHCOR(CL) --> = ICH si la classe consideree appartient
! au charbon ICH (1, 2, ...)
! DIAM20(CL) --> Diametre initial (m)
! DIA2MN(CL) --> Diametre minimum (m)
! RHO20(CL) --> Masse volumique initiale (kg/m3)
! RHO2MN(CL) --> Masse volumique minimale (kg/m3)
! XMP0(CL) --> Masse initiale de la particule (m) <=====
! XMASH(CL) --> Masse de cendres de la particule (m) <=====
as marked "<=====",the units "m" should be "kg"? please confirm! thanks.
(the question from code-saturne.info forum)
Leo
pls confirm the Units in cpincl.f90 of 2.1.4 ncs
Re: pls confirm the Units in cpincl.f90 of 2.1.4 ncs
Yes, the marked units description is false, but everything is in SI units, so kg seems right (I am not a specialist of this part of the code, but the only possible answers are kg or kg/m3 here, so if the comment itself is correct, kg is the right answer).
