gdb debugging
Boone11
gdb debugging
Post by Boone11 »
Hi all,
I want to use gdb to debug a computation. I read the web pagethat explain how to use gdb but I do not manage to run a computation with gdb.
I tried to go in the SCRIPT file and run the command:
gdb runcase
I get the following error message: not in executable format: file format not recognized
My runcase file is the following:
#!/bin/bash
export PATH=/home/david/Code_Saturne/5.3.4/code_saturne-5.3.4/arch/Linux_x86_64/bin:$PATH
# Run command:
\code_saturne run --param setup.xml
May you explain me how to run a computation Code_Saturne with gdb?
Thanks a lot,
Sincerely
Re: gdb debugging
You need to run gdb on the cs_solver executable, not on the script.
Did you read the debugging page specific to code_saturne (https://www.code-saturne.org/documentat ... gging.html) ?
I do not remember whether this feature was available in version 5.3 though, and in any case it may be less mature. But 5.3 has been retired since September 2019, so I recommend upgrading to a more recent version (either 7.0, the current stable version, or 7.3, which is a preview of the upcoming v8.0).
