Hi Community Members,
I have a .CGNS mesh file, which works alright in preprocessing mode and mesh import. All boundary faces are available from pre-processor.log file. But When giving run, the solver exited with the following error message
Post-calculation operations
solver script exited with status 137.
Error in calculation stage.
But there is no error message in listing file or error file in the RESU folder.
KIndly help
Re: solver script exited with status 137.
Do you have any relevant messages in your batch logs (error or standard) ?
sofenkumarjena
Error message getting in the GUI/Frontend
/media/skjena/251cfb2d-1a0c-4ca3-bb02-d0b32a0298fc/skjena/Code_Satrune_Results/unstructured_mesh/3D/RESU/20220701-1044/run_solver: line 11: 13577 Killed /home/skjena/Code_Saturne/5.3.4/code_saturne-5.3.4/arch/Linux_x86_64/libexec/code_saturne/cs_solver --param setup2430.xml $@
run solver message created in the RESU folder
#!/bin/bash
# Export paths here if necessary or recommended.
export LD_LIBRARY_PATH="/usr/lib/x86_64-linux-gnu/openmpi/lib":$LD_LIBRARY_PATH
export OMP_NUM_THREADS=1
cd /media/skjena/251cfb2d-1a0c-4ca3-bb02-d0b32a0298fc/skjena/Code_Satrune_Results/unstructured_mesh/3D/RESU/20220701-1044
# Run solver.
export CS_RET=$?
exit $CS_RET
No other error message for debugging. I am tried a lot not any success. The Mesh is in .cgns format
With Thanks and Regards
Sofen
#!/bin/bash
# Run solver.
export CS_RET=$?
exit $CS_RET
Sofen
The message just says the computation is killed, but does not say why. Did you try running it outside the GUI ? Are you using a batch system ?
