Heated Square Cavity Tutorial Solution
CyprienR
Post by CyprienR »
I have been trying to follow the Heated Square Cavity Tutorial and recreating the same results for few weeks now and I am still having issues getting the same velocity plot as in the PDF:
https://www.code-saturne.org/cms/web/si ... tyFlow.pdf
I am using Code Saturne 7.0.4
I think the problem is probably in my cs_user_physical_properties.c file
This is the routine I used:
void
cs_user_physical_properties2(cs_domain_t   *domain,
				cs_real_t t[])
  CS_NO_WARN_IF_UNUSED(domain);
  /* Check fields exists */
  if (CS_F_(lambda) == NULL)
    bft_error(__FILE__, __LINE__, 0,_("error lambda not variable\n"));
  if (CS_F_(rho) == NULL)
    bft_error(__FILE__, __LINE__, 0,_("error rho not variable\n"));
  if (CS_F_(cp) == NULL)
    bft_error(__FILE__, __LINE__, 0,_("error cp not variable\n"));
  cs_real_t *cpro_lambda = CS_F_(lambda)->val;
  cs_real_t *cpro_rho = CS_F_(rho)->val;
  cs_real_t *cpro_cp = CS_F_(cp)->val;
  cs_real_t *cpro_mu = CS_F_(mu)->val;
  cs_real_t *cpro_beta;
  cs_real_t vara=1000000; /* Rayleigh number */
  cs_real_t varb=1; /* Width between the plates */
  cs_real_t varc=10;  /* \Delta T= Th-Tc  */
  cs_real_t rho0= cpro_rho[0];/* 1.2039 */
  cs_real_t Cp0= cpro_cp[0]; /* 1004.84 */
  cs_real_t t0= 293.15; /* 293.15 */
  cs_real_t mu0= cpro_mu[0]; /* 1.83e-5 */
  cs_real_t gz= 9.81;
  /* Impose thermal conductivity, density and specific heat for solid zones */
    /* Volume zone "CM" must be defined in the GUI or in cs_user_zones.c */
    const cs_zone_t *z = cs_volume_zone_by_name("CM");
    for (cs_lnum_t i = 0; i < z->n_elts; i++) {
      cs_lnum_t cell_id = z->elt_ids[i];
      cpro_beta[cell_id] = cpro_lambda[cell_id]*mu0*vara/(pow(rho0,2)*Cp0*abs(gz)*varc*pow(varb,3));
      cpro_rho[cell_id] = rho0 - rho0*cpro_beta[cell_id]*(t[cell_id]-t0);
Could you let me know if you see some obvious mistake?
Thank you!
I also attach my whole case study with the Mesh, the XML and everything else.
Cyprien
heated_cavity.zip
(1.08 MiB) Downloaded 566 times
CyprienR
Re: Heated Square Cavity Tutorial Solution
Post by CyprienR »
I realised that the answer of this tutorial is available on Github here
Here is the link for those who have some difficulties to find it:
https://github.com/code-saturne/saturne ... are_Cavity
